How to get code off this fender tag ?
#2622648
02/17/19 07:20 PM
02/17/19 07:20 PM
Posts: 142 Near Columbus, Ohio
++MAX WEDGE++
Near Columbus, Ohio
Hello all, How can I tell what codes are on this fender tag? Any body out there that would be able to help get the missing codes as well? LMK your thought's. Thanks in advance.
Re: How to get code off this fender tag ?
[Re: ++MAX WEDGE++]
#2622652
02/17/19 07:27 PM
02/17/19 07:27 PM
Posts: 2,079 CA
crackedback
CA
[Re: crackedback]
#2622674
02/17/19 08:21 PM
02/17/19 08:21 PM
Posts: 43,576 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes, post a pic of the backside
JB Rhinehart, Realist
A-Body's RULE!
[Re: ++MAX WEDGE++]
#2622684
02/17/19 08:38 PM
02/17/19 08:38 PM
Posts: 1,460 Martinsville, IN
cdwmotorsports
Martinsville, IN
What those two intelligent men said...
If you are wanting to clean it up Id start with evaporust or a brass bristle brush and a gentle hand
Whats that from?
Its really difficult to tell if that's rust or orange peeling black paint.
My best guess so far is this
V6X V8X EN1 M21 N23 D?? V21 51 G11 G36 J5? G4X9 12 4 1802 4 566
eBay-cdwmotorsports
[Re: ++MAX WEDGE++]
#2622728
02/17/19 11:02 PM
02/17/19 11:02 PM
++MAX WEDGE++
Near Columbus, Ohio
Thanks for the help everybody I really apricate it. It's from a 72 duster twister car. Ill get photos of the back side and post asap.
[Re: ++MAX WEDGE++]
#2623172
02/19/19 01:07 AM
02/19/19 01:07 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Probably not 100% accurate but with some interpretive guesswork this should be pretty close.
VL29: Plymouth Duster - Base/low level model G = 318 V8 2 = 1972 model year B = Plant = Hamtramck, MI, USA 405664 =Sequence number E44 = 318 2 barrel V8 230hp D13 = 3 Speed Manual Transmission-Floor Shift EV2 = Hemi Orange Exterior Color C4X9 = Trim - Vinyl Split Bench Seat = Black TX9 = Black Upper Door Frames 418 = Scheduled Production Build Date = April, 18 1972 411902 = Order number EV2 = Hemi Orange Roof Color U = USA Specifications A51 = Duster "Twister" Package G11 = Tinted Glass (all) G36 = OS Dual Racing Mirrors J54 = Sport Hood
M25 = Wide sill moldings L31 = Hood/Fender Mounted Turn Signals M21 = Roof drip rail moldings N23 = Electronic Ignition System R11 = Radio Solid State AM (2 Watts) V21 = Performance Hood Treatment
V6X = Body Side Stripes, Black V8X = Tranverse Stripes, Black EN1 = End of Sales Codes
[Re: cdwmotorsports]
#2623499
02/19/19 11:27 PM
02/19/19 11:27 PM
cdwmotorsports
Martinsville, IN
Whats that from?
I feel pretty good with what I had pre back of tag pics. That thing was difficult to read at best. Awesome job to those that got the whole thing. To 6bblgt how did you make that “white fender plate image”?
eBay-cdwmotorsports
[Re: ScottSmith_Harms]
#2623510
02/19/19 11:44 PM
02/19/19 11:44 PM
++MAX WEDGE++
Near Columbus, Ohio
If you decide to soak it to remove the rust I'd recommend Evaporust not acid (vinegar). Also, Dan's tag decipher may be more accurate concerning the L25 vs M25. Does your car have a trunk light? Rocker moldings? Yes car has trunk lite. It does not have on it (currently) rocker moldings but that not to say they weren't there, I would have to check and see if there is clips there that might have held them on at one time. Is there a big difference between L25 and M25?
#2623515
02/19/19 11:53 PM
02/19/19 11:53 PM
++MAX WEDGE++
Near Columbus, Ohio
If ever there was a car that needed a new fender tag made.
What’s the rest of the car look like? Believe it or not it has a super solid frame and trunk.....crazy I know
#2623856
02/20/19 06:45 PM
02/20/19 06:45 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
VL29: Plymouth Duster - Base/low level model G = 318 V8 2 = 1972 model year H = Plant = Hamtramck, MI, USA Scott, since we're trying to help him decipher his codes properly, I need to correct you. As you know, "H" would be the 340 engine code. "B" as the 7th digit would be the plant code for Hamtramck, not "H".
#2623899
02/20/19 08:29 PM
02/20/19 08:29 PM
++MAX WEDGE++
Near Columbus, Ohio
Absalutely, brain fart on my part. I was typing that fat fingered on my cell phone and made a few changes, scrambled it somehow. I fixed it. Any thoughts on production numbers with the "Twister Package" and What is a "Twister Package" ???? Thanks Scott
