Re: Fuel tank foam question
[Re: tubtar]
#2622539
02/17/19 02:56 PM
02/17/19 02:56 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I used the technical expertise and parts from these guys to update my fuel tank. They know tank design theory, foam placement etc. and are very helpful. Great customer service and expertise. https://www.harmonracingcells.com/Rick's Tanks built the larger tank using my spec's and they did a great job of baffling it. I get no fuel slosh out the filler neck. Later, I upgraded the inner-workings with the help & guidance of Harmon Racing Cells. First photo shows internal baffling and a pair of Holley Hydramats with -10 fittings and fuel-submersible rated fuel lines. My 2-speed Fuelabs fuel pump is mounted just outside the tank and up near the top of the tank to protect it from road debris and provide easy access. This set-up provides air free fuel down to the last few ounces of fuel in the tank whether drag racing or on a road course.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 8pack]
#2624036
02/21/19 12:48 AM
02/21/19 12:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I heard 3rd hand about people having problems with the foam coming apart and I got scared and pulled my foam out. I have only seen this on an F-15 that had an internal fuel tank fire...and it flew for years until we figured out what caused the foam to break up.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2624140
02/21/19 12:16 PM
02/21/19 12:16 PM
Posts: 22,732 Bitopia
jcc
Bitopia
I would not glue the foam in with any permanent glues. Most foams in our applications, have a limited lifespan. I would not favor what it takes to remove old permanent glue when time comes to replace the foam.
[Re: astjp2]
#2624147
02/21/19 12:34 PM
02/21/19 12:34 PM
Posts: 34 nor cal
8pack
nor cal
I heard 3rd hand about people having problems with the foam coming apart and I got scared and pulled my foam out. I have only seen this on an F-15 that had an internal fuel tank fire...and it flew for years until we figured out what caused the foam to break up. Many Ag airplane also use foam. That said aviation has very struck fuel standards so they can build the foam to resist breaking down.
[Re: tubtar]
#2625759
02/25/19 05:37 AM
02/25/19 05:37 AM
astjp2
Utah and Alaska
I have dealt with the ASTM specs for avgas and gasoline, gasoline is actually regulated to a stricter standard than Avgas because so many local emission rules apply to cars and not airplanes. I build a fuel valve for an antique airplane so I did lots of research on the topic. Tim
