1970 Charger sunroof drains #2622369
02/16/19 11:34 PM
02/16/19 11:34 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
I as wondering if anyone might have detailed pictures of the routing of the drain tubes for the sunroof and also where the rear tubes exit the car.Any help would be appreciated.Thanks..
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1970 Charger sunroof drains [Re: charge70] #2622507
02/17/19 01:13 PM
02/17/19 01:13 PM
California
biggE Offline
biggE  Offline
California
I know that with 70 Challengers the drain tubes exited through the rear wheel housings. It was very crudely done. Seems like they had some sort of a steel rod that they pounded through the area with a hammer until it was large enough for the drain tube to fit through. Then they sealed around the tube by hand with some pliable sealer.
Re: 1970 Charger sunroof drains [Re: charge70] #2622636
02/17/19 06:55 PM
02/17/19 06:55 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
I understand that they run down the roof pillar and exit thru the wheel tub.I was just looking for pics that would verify me being correct on the routing of the hoses thru the pillar structure as there are a few different ways they could be run.I don't want problems later when I put the headliner in and end up with a lump or bump in the material from the drain tube.
