Correct Finish on Gas Pedal Assembly #2622220
02/16/19 05:28 PM
02/16/19 05:28 PM
MD
floyd Offline OP
floyd  Offline OP
MD
What is the correct finish on a 70-71 E-body gas pedal assembly? Bare metal, black phosphate, etc? I'm guessing Sublime is wrong? smile
Thanks!
Re: Correct Finish on Gas Pedal Assembly [Re: floyd] #2622235
02/16/19 06:06 PM
02/16/19 06:06 PM
Mass
Mike Mancini Offline
Mass
Phosphate w/ rubber dipped end at cable mount.
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: Correct Finish on Gas Pedal Assembly [Re: Mike Mancini] #2622252
02/16/19 07:02 PM
02/16/19 07:02 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks!
Re: Correct Finish on Gas Pedal Assembly [Re: floyd] #2623588
02/20/19 03:09 AM
02/20/19 03:09 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
From my unrestored 1970 Cuda. Just removed it to replace the broken pedal spring. I have attached a couple of pictures with different lighting.
David
Re: Correct Finish on Gas Pedal Assembly [Re: David1971] #2623743
02/20/19 03:46 PM
02/20/19 03:46 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Awesome! Looks like studs that go through the firewall were black. Does that look like bare steel where most of the phosphate has worn off, or was it something other than black phosphate?
Re: Correct Finish on Gas Pedal Assembly [Re: floyd] #2624077
02/21/19 03:33 AM
02/21/19 03:33 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I think the phosphate finish has worn off. I will look at the studs again and take a couple of closeup pictures...... Update: After a second look, I agree the washing that I gave the assembly caused a reflection on the heads of the studs. The phosphate finish looks fine.
David
Re: Correct Finish on Gas Pedal Assembly [Re: floyd] #2624115
02/21/19 10:42 AM
02/21/19 10:42 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Looks like its wet in the pic you attached, the bare steel appears to be showing a bit. The finish is "phosphate" but to be more specific, Zinc Phosphate, which produces shades of grey. Color varies on these based on bath strength, time in solution, temperature of bath, and material finish. A fresh bath may produce a color some would call black. If you really want black (incorrect from my experience) use a fresh bath of Manganese Phosphate.
Phosphate coatings, zinc or manganese, are not particularly good corrosion inhibitors. They receive their corrosion resistance through a post plating oil dip, where the coating structure accepts and holds trace mounts of oil, the same reason you oil a gun surface. If you do the plating yourself you can use a sealer (a clear coat of sorts) that will not attract dust/dirt and will perform well as a corrosion inhibitor.
