Re: 73 Barracuda - ECS
[Re: BcudaChris]
#2627110
02/28/19 02:48 PM
02/28/19 02:48 PM
Posts: 403 Colorado front range
BcudaChris
Thanks guys, I have been waiting for an an unseasonably warm day for a real test before posting an update, since there is interest though...
All is working as it should, but no warm(er) weather test. No hard starting when hot, no flooding from excess tank pressure.
I also went through my vapor canister, and found the purge valve diaphragm to be in perfect shape, but all the purge passages were clogged with charcoal dust. I thoroughly cleaned the canister out and replaced the charcoal with stuff for a fish tank. I used pellets instead of granular hoping to keep it out of the purge valve. Since then, I have noticed new fuel smells in the garage after shut down and in the car as things come up to temp. I'm thinking I may add some granular charcoal to try and fill the air spaces left by the pellets.
Of note on the smells, I did not notice them when I had tanked up with pure 91, only with oxygenated Old Milwaukee gas. Unfortunately, the pure 91 is still $3.70 a gallon, while the Old Mildoggie is in the $2.30's.
Warm days expected today and tomorrow, and I'm driving it to work tomorrow. I'll report back with the results.
