Open track & autocross carburetor recommendations? #2621138
02/14/19 03:55 AM
02/14/19 03:55 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
What are you guys running for carbs on your track day cars?
The Red Brick ran a BLP 650 CFM carb that performed flawlessly, but cost $1000
Any decent carbs that would work that don't cost $1000? I need a carb for my stock 5.9/ 360 but plan to convert to a Gen 3 Hemi later this year/ next winter.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2621185
02/14/19 11:22 AM
02/14/19 11:22 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Any decently calibrated 4150/60 with centerhung floats will be fine. Some of us found front jet extensions help prevent them from dying at end of hard braking - especially to a dead stop.
Tim made an AFB work on the Valiant's earlier engines, back when he ran it in Street Mod. So clearly they can be used as well, although some tweaking may be needed.
With a Holley or Carter chose something older that hasn't been molested as the calibrations are generally better (as was QC).
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2622005
02/16/19 03:26 AM
02/16/19 03:26 AM
AndyF Offline
AndyF  Offline
I got that BLP carb at no cost since it was featured in a magazine article but you're correct, the average guy is going to pay a lot for a full race carb like that one.
If I was working on the Brick these days I'd sell that carb and put a Holley Sniper on there. I'd much rather spend $1000 on EFI than on a carb. The Holley Sniper will run better than a carb since there won't be any fuel slosh and it has a built in data logger. We would've loved to have a data logger on the Brick. That would've been awesome for track days. Back then it was super expensive to buy a data logger and now they come for free when you buy a $995 EFI system.
Re: Open track & autocross carburetor recommendations? [Re: AndyF] #2622023
02/16/19 05:16 AM
02/16/19 05:16 AM
USA
Consulier Offline
Consulier  Offline
USA
The Taxi runs an out of the box Quickfuel 750 Vac Secondary. Has the Jet Extensions, but I'm pretty sure it came with those. We've messed with Vac Springs and Jets, that's it.
Never had an issue at Track Day's or Autocross.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2622118
02/16/19 01:57 PM
02/16/19 01:57 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thank you for the replies. I'll be buying a carb this week.
AndyF, yes the few things that car needs to make it perfect, would be fuel injection, 5 speed, and a paint job. Its crazy how much all the stuff has come down in price.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2622137
02/16/19 02:52 PM
02/16/19 02:52 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I don't know about paint. I like the sleeper look on that car.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2622544
02/17/19 03:05 PM
02/17/19 03:05 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I have a AED carb, they make them for circle track racers.... I believe it was around $750US a few years ago.
I’m currently building a new small block for the car and can’t see why I would use anything other than a Holley sniper on it unless something better hits the market in the next few months.
A new iron curtain drawn across the 49th parallel
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2622626
02/17/19 06:32 PM
02/17/19 06:32 PM
AndyF Offline
AndyF  Offline
Unless the rules require a carb I'd run EFI these days on any track or autocross car. I don't see any reason to have fuel sloshing around in a carb when you can bolt on a throttle body. Not to mention the auto tuning and data logging that you get.
Re: Open track & autocross carburetor recommendations? [Re: AndyF] #2623548
02/20/19 01:13 AM
02/20/19 01:13 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I had this problem on my first autocross event with the Dart. Out of the gate, there was a hard right turn, and 3 out of 4 of my runs the carb flooded and I was DQed. It was quite embarrassing.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2623577
02/20/19 02:37 AM
02/20/19 02:37 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
If you are converting to a gen 3 hemi why not get the fuel injection pump in the fuel tank and upgraded fuel lines now to "prepare" for the conversion? Then grab a Holley Sniper as others have mentioned...
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2624701
02/22/19 02:30 PM
02/22/19 02:30 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I run a 830 quickfuel with electric choke, mechanical secondaries and annular boosters and ran a few autox races and never once had it fail on me. I will be selling it here sometime soon as I am upgrading to efi
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2624704
02/22/19 02:34 PM
02/22/19 02:34 PM
dangina Offline
dangina  Offline
on a off topic do you guys prefer the fitech or the holly?
Re: Open track & autocross carburetor recommendations? [Re: dangina] #2624995
02/23/19 04:28 AM
02/23/19 04:28 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I recently went with Holley as I heard Fitech had some customer services issues for a while. Holley is supposed to be better with support. So far I have not needed customer support for my Sniper, so I have no personal experience. Price is not that far apart with Summit running its $101 off $1000 special now. There is a lot you can do with the Sniper besides letting it self tune, but I have no knowledge how Fitech compares there.
Re: Open track & autocross carburetor recommendations? [Re: NV69B7RR] #2626578
02/27/19 01:07 AM
02/27/19 01:07 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks for the replies. I did buy the Tanks Inc tank, as I knew I could use that in the future. I may just go with a fuel injection set up and that good to know about the Holley.
