Hesitation, stalling - torque converter?
#2621497
02/15/19 12:47 AM
02/15/19 12:47 AM
Posts: 1,177 People's Republic of Kali
70runner
69 Charger 440 RT auto. Fresh, stock rebuild with new Edelbrock 1813 (800cfm) carb, stock points ignition. Starts and idles fine, base timing @12, all in @35. Off idle hesitation before rebuild (with orig AVS), tuning helped but not fully eliminated. Now occurring after rebuild with Edelbrock linkage in the "rich" hole. More recently, occasionally stalls at idle in drive. Starts right back up. Trans has been rebuilt, shifts properly. No unusual sounds (TC clacking/whirring). We didn't change the TC when the engine was rebuilt, so its the original unit. Could the TC be the problem?
Re: Hesitation, stalling - torque converter?
[Re: 70runner]
#2621504
02/15/19 01:01 AM
02/15/19 01:01 AM
RapidRobert
It ain't the TC. since it did it on both carbs I would assume the A/P squirt tip in was immediate. a vac leak will do it (vac can/valley pan are potentials) as will E10 gas. Mixture screws out enough turns?
[Re: 70runner]
#2621543
02/15/19 03:44 AM
02/15/19 03:44 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I agree with Rapid Robert
Anyways "Stalls at idle in drive - Hesitation off idle"
What intake are you running ? Open plenum or divided - Did you check for vacuum leaks ?
Also you mentioned points ignition - How new are the points , and gap/dwell setting ?
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 70runner]
#2621548
02/15/19 05:14 AM
02/15/19 05:14 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
When did the problem start with last engine? Was it still stock ignition. I looked at your resto thread again. Is there rust or scale in the gas tank?
Check for a vacuum leak, PB booster, vac headlight system, A/C vacuum lines, etc. disconnect and plug vacuum lines and try it. Accelerator pump system.
What camshaft? What compression ratio? Is it too low now? What distributor and ignition system?
Paid like to see the original carb restored and back on there, edelbrocks bring drivability problems with them esp on BB engines.
We know you do good work, must be frustrating, for now.
[Re: 70runner]
#2621612
02/15/19 12:07 PM
02/15/19 12:07 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There are certainly a lot of things that can contribute to your problem, but the torque converter is not the first item that comes to mind.
The first 2 things that stand out to me with the information provided. A)the initial timing is a little low and the curve is a little slow. And B)the CarterBrocks are often a poor choice given their well deserved reputation for drive-ability issues.
Our big blocks really respond to timing. Throw 5* to 8* more timing at it and try a test drive. No full throttle blasts with that much timing, just a short drive around to see if it helps the stumble.
And see if someone has a known-good carb that you can borrow and try.
Master, again and still
[Re: bee1971]
#2621766
02/15/19 05:52 PM
02/15/19 05:52 PM
70runner
Also you mentioned points ignition - How new are the points , and gap/dwell setting ? Intake is original stock. Have checked for vac leaks, will check again. Points relatively new, dwell setting good.
[Re: NANKET]
#2621775
02/15/19 06:04 PM
02/15/19 06:04 PM
70runner
We know you do good work, must be frustrating, for now. Problem was evident with engine when we bought it, stock points setup. Tank relatively new. I'll have to dig into the engine rebuilder info to get cam/CR info (daughter/owner has all that). Stock, reman points dizzy, stock coil...replaced failed Firecore all in one installed by engine rebuilder. VERY frustrating. We've discussed sending orig AVS to Harms. May do that now. Also may upgrade ignition system to Mopar electronic, see if that helps. The stalling is what made me think of the TC. We had a problem earlier with a worn fuel pump rod. Gonna check that again as well.
[Re: DaveRS23]
#2621778
02/15/19 06:11 PM
02/15/19 06:11 PM
70runner
And see if someone has a known-good carb that you can borrow and try. I was contemplating same thing...adding some timing to see what effect it has. My 70RR 440-6 is @ 19base, 35 total, but has a cam and, of course, I can't swap carbs with it Can you/anyone recommend a better replacement carb until we decide what to do with the orig AVS? I don't much care for the electronic choke on the edelbrock anyway.
[Re: 70runner]
#2621783
02/15/19 06:24 PM
02/15/19 06:24 PM
RapidRobert
Just me I would do a compression test which would confirm the long block (including t chain cam timing/head gasket sealing etc) is Ok if you get good numbers. I'll assume that the dampener ain't slipped (for now) but wouldn't hurt to confirm it with the $10 plug hole 14MM screw in tool. My 1406 600 eddy needed richer jetting from a strip kit on a DD & the elec choke came off way too fast but first what I would do on yours is block the rods up on your carb & see what being on the power circuit full time does for the driveability which might help confirm a vac leak and or lean jetting and or lean choke (easy to do/free/takes little time). EDIT & yes bump the initial up (I have 19 on a bone stock 318)
[Re: 70runner]
#2621877
02/15/19 10:19 PM
02/15/19 10:19 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And see if someone has a known-good carb that you can borrow and try. I was contemplating same thing...adding some timing to see what effect it has. My 70RR 440-6 is @ 19base, 35 total, but has a cam and, of course, I can't swap carbs with it Can you/anyone recommend a better replacement carb until we decide what to do with the orig AVS? I don't much care for the electronic choke on the edelbrock anyway. As I have said before, our big blocks like a lot of initial timing and the mechanical advance in as quick as the combo allows. At idle, twist the distributor advanced until it doesn't like it anymore, then just back it up a touch and check the timing. Most will like it somewhere in the low 20s with a mild cam. Hotter cams with rougher idle like even more. The only limit on the idle advance is if it hits back against the starter when cranked hot. Overall, for a big block, as high an idle advance and as fast a mechanical advance as the engine will take without developing other bad habits. As long as it doesn't cause other problems, low 20s for idle advance and all in by mid 2,000s RPMs. My current Hemi idles at 25* and is all in by 2,200. Which is about where my wedges end up at. And I think everyone here knows that I am a big fan of the Street Demon carbs. They are hands down, the best carb out there for a mild street engine. Do a search and you will find a number of threads here on this subject along with links to tests and dyno sessions.
[Re: NANKET]
#2622317
02/16/19 09:59 PM
02/16/19 09:59 PM
70runner
What’s wrong with the original AVS? Is it a 4640? It should be a 750 cfm, equal size primary & secondary throttle plates.
Don’t pile on me for this but I don’t think electronic ignition will help, but it doesn’t hurt to try. Don’t mount the box tight away, just bolt a ground wire to it and drive that way to see if it helps.
Hate to drill holes in the new Underwood paint job was in that nice Charger. I believe it is a 4640. Butterfly shafts worn. We were having hesitation with it as well. If it ever stops raining here in No San Diego county, will probably do the timing first, see what happens with that. I kinda agree with you, the electronic conversion probably won't solve the issue.
