'71 Challenger grille #2621168
02/14/19 10:13 AM
02/14/19 10:13 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Guys/gals:
Helping a friend with putting his grille together on his '71. He got his car in pieces with little hardware. What hardware is needed, and where to purchase, to install the grill and for around the headlights?
Thanks!
Re: '71 Challenger grille [Re: 71rm23] #2621451
02/14/19 10:24 PM
02/14/19 10:24 PM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
Hardware for a 1971 R/T Challenger
https://www.ebay.com/itm/Mopar-71-Challenger-R-T-Grille-Fastener-Hardware-Bolt-Kit-Set-NEW-271121/332595448301?fits=Year%3A1971%7CModel%3AChallenger%7CSubmodel%3AR%2FT&hash=item4d703bc9ed:g:LccAAOSwgKBatDVZ:sc:USPSFirstClass!44646!US!-1:rk:4:pf:1&frcectupt=true
Hardware for a 1971 non R/T Challenger
https://www.ebay.com/itm/Mopar-71-Challenger-Grille-Fastener-Hardware-Bolt-Kit-Set-NEW-271122/372317333065?fits=Year%3A1971%7CModel%3AChallenger&epid=1731516763&hash=item56afd7a649:g:SUwAAOSw7m9bCtXT:sc:USPSFirstClass!44646!US!-1:rk:4:pf:1&frcectupt=true
Re: '71 Challenger grille [Re: KillerBee] #2621453
02/14/19 10:28 PM
02/14/19 10:28 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Classic Industries, part number MN3098 or MN3099
Re: '71 Challenger grille [Re: KillerBee] #2621456
02/14/19 10:35 PM
02/14/19 10:35 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
The screws for headlight bezels that attach directly to the fender use a clip nut and sheet metal screw. The ends of the grille that attach directly to the fender use clip nuts also. The top of the grill to steel grille header uses a large head plastic push pin. there are angle brackets that attaché the backside of grille and uses hex head bolts. As a very last resort, I can take some of my fasteners out of my car to see the size. Usually the hex held bolts are 1/4" -20bolts. I can remove some of the screws if no one else has the information handy. Just a pain to remove parts. Someone over at the ebodies.org website may have the info handy.
Terry
Re: '71 Challenger grille [Re: 71rm23] #2621626
02/15/19 12:39 PM
02/15/19 12:39 PM
None
71rm23 Offline OP
71rm23  Offline OP
None
I appreciate it Killerbee and Terry!
