Re: New Engine Won't Start [Re: jim6346] #2621338
02/14/19 04:32 PM
02/14/19 04:32 PM
I reread your OP, you have compression. with your tester all plugs are firing. you have confirmed you are on #1 compression. I'll assume fresh gas in the carb. All that is left is something is missing in the dist setup/timing assuming no vac leak. Each set of points connected to the coil neg pri is correct. the EDIT info I posted prior came from the Jacobs ign bible, you might see where you are at with that. & I would time it at 15.
Re: New Engine Won't Start [Re: jim6346] #2621373
02/14/19 06:04 PM
02/14/19 06:04 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
OK, got her running, something weird is up, had to rotate the distributor almost 25 degrees. Not even close to the timing marks, but runs smooth as hell.
Thanks everyone for you help!!
Re: New Engine Won't Start [Re: jim6346] #2621411
02/14/19 08:39 PM
02/14/19 08:39 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Sounds like the intermediate shaft isn't lined up where it should be, most likely off a tooth. With the engine at TDC (#1 Cylinder) the slot on the intermediate shaft should be pointing vertical (up & down).
Re: New Engine Won't Start [Re: jim6346] #2621414
02/14/19 08:45 PM
02/14/19 08:45 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If I read Jim's post correctly sounds like the timing marks are off.
Re: New Engine Won't Start [Re: 340Cuda] #2621444
02/14/19 10:10 PM
02/14/19 10:10 PM
timing tab is on pass side & timing light is showing way CCW past the tab? How far would you guestimate? ported or manifold? what idle speed?
Re: New Engine Won't Start [Re: jim6346] #2621522
02/15/19 02:15 AM
02/15/19 02:15 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Glad to hear it's running. Hope you didn't wipe your cam.
Re: New Engine Won't Start [Re: jim6346] #2621531
02/15/19 03:00 AM
02/15/19 03:00 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
If your timing marks are that far off, you could have a slipped timing chain, or the harmonic balance has slipped on the hub, or you have the wrong timing chain cover markings.
I would want to determine the true top dead center and see what is off. Gene
Re: New Engine Won't Start [Re: jim6346] #2621849
02/15/19 09:16 PM
02/15/19 09:16 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Find your true top dead center first and then check it against you balancer and cover markings.
These are cheap -
Re: New Engine Won't Start [Re: jim6346] #2622456
02/17/19 03:10 AM
02/17/19 03:10 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Check the other suggested possibilities first, but is it possible that the harmonic damper is bad?
