1971 340, 4spd California transmission switch #2620894
02/13/19 06:43 PM
02/13/19 06:43 PM
California
biggE Offline OP
biggE  Offline OP
California
I have a 1971 cuda 340, 4spd that is an original California car. I am restoring the transmission and in the side cover is a switch that is activated when the car is put into fourth gear. I assume to meet the CA emissions at the time it retarded the timing in 4th gear only. The male lead is broken off of the switch and I'd like to find a replacement. The reference picture is of a unmolested trans in another car. The 70-71 parts book has a picture of it but the referenced part number leads to a two prong backup light switch. Any help in finding the switch is appreciated.
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2620895
02/13/19 06:46 PM
02/13/19 06:46 PM
California
biggE Offline OP
biggE  Offline OP
California
I found this switch that was used on GM 4spd cars around the same year but the thread diameter is to small to work.
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621028
02/13/19 11:17 PM
02/13/19 11:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
E
Is this a late build car?
You might have to use the two pin and then run a ground wire to one of the pins.
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621059
02/14/19 12:09 AM
02/14/19 12:09 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I might have an original. Can you carefully degrease/clean the one in your picture and retake the picture both connected and disconnected?
Re: 1971 340, 4spd California transmission switch [Re: ScottSmith_Harms] #2621072
02/14/19 01:16 AM
02/14/19 01:16 AM
California
biggE Offline OP
biggE  Offline OP
California
Scott, here are a few of the original switch with the broken connector. There are some numbers stamped into it, I believe from the manufacture.
472
58024
2220
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621073
02/14/19 01:17 AM
02/14/19 01:17 AM
California
biggE Offline OP
biggE  Offline OP
California
#2
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621074
02/14/19 01:17 AM
02/14/19 01:17 AM
California
biggE Offline OP
biggE  Offline OP
California
#3
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621090
02/14/19 01:55 AM
02/14/19 01:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Can you post a pic of the wire connector terminal end?
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621541
02/15/19 03:40 AM
02/15/19 03:40 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
472
58024
2220
So it was made 222 of 70 and the vendor was 58024
Re: 1971 340, 4spd California transmission switch [Re: ScottSmith_Harms] #2621542
02/15/19 03:40 AM
02/15/19 03:40 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's the part that is broken off.
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621588
02/15/19 10:52 AM
02/15/19 10:52 AM
VA
dragon slayer Offline
VA
He is asking for the wire end terminal. Not switch terminal. Learn something new. I have seen that boss on the side plates, but never seen a California Transmission with the switch.
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621668
02/15/19 02:17 PM
02/15/19 02:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As far as the switch is concerned, Im pretty sure JS Restorarions can repair that missing spade on that switch
Re: 1971 340, 4spd California transmission switch [Re: biggE] #2621716
02/15/19 04:06 PM
02/15/19 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is it part number 3438472? That's the NOX switch number.
