Page 1 of 3 1 2 3
Kickdown - really needed? #2620418
02/12/19 07:20 PM
02/12/19 07:20 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello folks,
transmission builder is finishing my 904 and I told him that I wasn't planning to use the kickdown. He was very upset and said it´s mandatory to use it.
Sorry my ignorance but is this true? Wha would be the issues of not using it?
Car will be street/strip...
Thanks,
1973 Brasilian Dart
E100, boosted 390"
Re: Kickdown - really needed? [Re: dart_73_br] #2620422
02/12/19 07:24 PM
02/12/19 07:24 PM
Guitar Jones Offline
If you are not using a manual valve body then yes, it is mandatory otherwise front clutch failure will soon follow.
Re: Kickdown - really needed? [Re: dart_73_br] #2620426
02/12/19 07:30 PM
02/12/19 07:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need to understand that kickdown is an incorrect name for the linkage you are talking about . It is actually throttle pressure linkage and that tells you why it's necessary. It actuates a valve in the valve body that adds pressure to the system as you increase power to keep the clutches and bands applied rather then slipping and burning up. With out that linkage the trans will fail very quickly unless you have a manual valve body in it.
Re: Kickdown - really needed? [Re: dart_73_br] #2620428
02/12/19 07:31 PM
02/12/19 07:31 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Will use Transgo TF2 shift kit...
1973 Brasilian Dart
E100, boosted 390"
Re: Kickdown - really needed? [Re: dart_73_br] #2620433
02/12/19 07:33 PM
02/12/19 07:33 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
TF2 Don’t matter, you will be pulling it out after 200 miles or less. You have been warned.
Re: Kickdown - really needed? [Re: dart_73_br] #2620434
02/12/19 07:35 PM
02/12/19 07:35 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you need it, if you don't have it, you'll blow your trans. if you don't want to use it, you need a manual valve body
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Kickdown - really needed? [Re: dart_73_br] #2620470
02/12/19 08:19 PM
02/12/19 08:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Shift kit DOES NOT replace the linkage.
Re: Kickdown - really needed? [Re: stumpy] #2620472
02/12/19 08:23 PM
02/12/19 08:23 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You don't have to use the TV linkage. But when the trans takes a dump prematurely, you'll wish you had.
Re: Kickdown - really needed? [Re: 6PakBee] #2620473
02/12/19 08:26 PM
02/12/19 08:26 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Ha ha, exactly. haha
Scott
1969 Super Bee, 383/4 speed
Re: Kickdown - really needed? [Re: StukaJU87] #2620495
02/12/19 09:35 PM
02/12/19 09:35 PM
The TF-2 kit gets good reviews & I think with an adjusted correctly kickdown & the largest cooler that will fit in front of the rad that you will be good to go.
Re: Kickdown - really needed? [Re: dart_73_br] #2620502
02/12/19 09:44 PM
02/12/19 09:44 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
FIND a new Trans guy ... whistling
Re: Kickdown - really needed? [Re: dart_73_br] #2620514
02/12/19 10:04 PM
02/12/19 10:04 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
FWIW, I ran my car years ago without the linkage; it was not installed when I took ownership of the car. Best guess, the rebuild had maybe 3-4000 miles on it. I built another motor and had the tranny re-freshed at that time. My low/reverse band was burnt up. There were a few other small parts that were bad too but, it's been so long, I can't remember.
At the time, the tranny was not doing anything stupid, I was just going to put some more power to it and had it out so; I thought it was an opportune time to have it gone through.
If I can remember right, I put a couple hundred miles on the re-build without the linkage too. At that time, I learned of the importance of the linkage. The car was my dad's and my brother still owned his house so; I pretty much knew where all that stuff was. I went to my brother's house, located all the parts other than the bell crank (I bought that used of E-bay) and I installed it all.
I have probably 6000 miles on the tranny without issue.
Re: Kickdown - really needed? [Re: dOOc] #2620558
02/12/19 11:23 PM
02/12/19 11:23 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why? The transmission guy was right. Do you abandon someone that gives you correct advice?
Re: Kickdown - really needed? [Re: dart_73_br] #2620621
02/13/19 01:35 AM
02/13/19 01:35 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you want a more exact throttle pressure linkage without the rods use the Bouchillion cable kit along with their throttle cable bracket. I have used them multiple times over the years with great success
If you want to ditch the linkage you may as well zip tie the pressure wide open and go
Re: Kickdown - really needed? [Re: Kern Dog] #2620633
02/13/19 02:21 AM
02/13/19 02:21 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Well FRANKENfurter.... why don’t you delete that KD on yurr FRANKENcharger and seabhowvthatvwerks ferr u !! smoke
Re: Kickdown - really needed? [Re: dart_73_br] #2620637
02/13/19 02:28 AM
02/13/19 02:28 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Doc F, don't be giving wrong advise about the KD linkage. It is necessary unless it's a full manual automatic.
Re: Kickdown - really needed? [Re: dart_73_br] #2620640
02/13/19 02:58 AM
02/13/19 02:58 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Doc is backwards again. The Trans guy said it was mandatory. I agreed. Where is the confusion?
Re: Kickdown - really needed? [Re: dart_73_br] #2620647
02/13/19 03:34 AM
02/13/19 03:34 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I picked up on where Doc was going with it.
He was being sarcastic about why the OP would be questioning his trans guy's intelligence.
Re: Kickdown - really needed? [Re: dart_73_br] #2620703
02/13/19 10:35 AM
02/13/19 10:35 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
Ok, so looks like the concense it that I need it.. smile I just want to find the best way to do it as I don't have the linkages.. maybe cable is the easier way to go...
There´s some old chrysler video here...
1971 Master Technician Service Conference
https://youtu.be/KsfI9cFFPpg
1973 Brasilian Dart
E100, boosted 390"
Re: Kickdown - really needed? [Re: BulletBob] #2620722
02/13/19 11:53 AM
02/13/19 11:53 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
To BullBob and the rest ! ..., no sarcasm on my part !! ... jsta total BRAIN FADE on my part ! I misread it..... BIG TIME.
BUTTT .. You CAN drive without KD linkage if you tie the lever back about a third of the way ..., if you drive it EZ. Do thatt - then put in a WANTED AD back in the swap meet section here and get the right OEM parts. I have never used a cable set up .... I’ve heard mixed reports about that setup....
FRANKENfurter ... I’ll EAT CAKE on this one ! coffee
Page 1 of 3 1 2 3
