Kickdown - really needed?
#2620418
02/12/19 07:20 PM
02/12/19 07:20 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Hello folks,
transmission builder is finishing my 904 and I told him that I wasn't planning to use the kickdown. He was very upset and said it´s mandatory to use it.
Sorry my ignorance but is this true? Wha would be the issues of not using it?
Car will be street/strip...
Thanks,
1973 Brasilian Dart E100, boosted 390"
Re: Kickdown - really needed?
[Re: dart_73_br]
#2620422
02/12/19 07:24 PM
02/12/19 07:24 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
If you are not using a manual valve body then yes, it is mandatory otherwise front clutch failure will soon follow.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: stumpy]
#2620472
02/12/19 08:23 PM
02/12/19 08:23 PM
Posts: 10,707 North Dakota
6PakBee
North Dakota
You don't have to use the TV linkage. But when the trans takes a dump prematurely, you'll wish you had.
[Re: 6PakBee]
#2620473
02/12/19 08:26 PM
02/12/19 08:26 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
You don't have to use the TV linkage. But when the trans takes a dump prematurely, you'll wish you had. Ha ha, exactly.
Scott
1969 Super Bee, 383/4 speed
[Re: StukaJU87]
#2620495
02/12/19 09:35 PM
02/12/19 09:35 PM
RapidRobert
The TF-2 kit gets good reviews & I think with an adjusted correctly kickdown & the largest cooler that will fit in front of the rad that you will be good to go.
[Re: dart_73_br]
#2620703
02/13/19 10:35 AM
02/13/19 10:35 AM
dart_73_br
Sao Paulo, Brazil
Ok, so looks like the concense it that I need it.. I just want to find the best way to do it as I don't have the linkages.. maybe cable is the easier way to go... There´s some old chrysler video here... 1971 Master Technician Service Conference https://youtu.be/KsfI9cFFPpg
[Re: BulletBob]
#2620722
02/13/19 11:53 AM
02/13/19 11:53 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
I picked up on where Doc was going with it. He was being sarcastic about why the OP would be questioning his trans guy's intelligence. To BullBob and the rest ! ..., no sarcasm on my part !! ... jsta total BRAIN FADE on my part ! I misread it..... BIG TIME. BUTTT .. You CAN drive without KD linkage if you tie the lever back about a third of the way ..., if you drive it EZ. Do thatt - then put in a WANTED AD back in the swap meet section here and get the right OEM parts. I have never used a cable set up .... I’ve heard mixed reports about that setup.... FRANKENfurter ... I’ll EAT CAKE on this one !
