S/S Springs - Loose Front Spring Clamp #2620582
02/13/19 12:16 AM
02/13/19 12:16 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
I have had the passenger forward spring clamp on my e-body S/S springs walk back a couple of inches. I knocked it forward and tired to pinch it a bit tighter.
Should I consider replacing it, if so, where would I find a replacement?
Would there be any adverse effects of adding another clamp to the first two leaves, closer to the forward mount while I'm at it?
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2620602
02/13/19 01:07 AM
02/13/19 01:07 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
clamp the front segmets and gain some perormance !
Re: S/S Springs - Loose Front Spring Clamp [Re: calrobb2000] #2620666
02/13/19 05:34 AM
02/13/19 05:34 AM
Originally Posted By calrobb2000
hi
iagree
I would, and have , added clamps on every front half of those type springs and the car went faster after that up
You might want to remove the anti squeak strips also at the same time scope thumbs
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2620702
02/13/19 10:31 AM
02/13/19 10:31 AM
Oklahoma
Oklahoma
Thanks, any particular source or type of clamp?
Should they be clamped at ride height, unloaded? Does it matter?
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2620838
02/13/19 04:01 PM
02/13/19 04:01 PM
I use 1/4 inch thick 1 inch wide straps with 3/8 bolts, installed with all the weight on them up
A friend of mine found out he could make the front of his drag car raise up equally by moving the clamps behind the rear end housing, I tried it later on my 1969 Dodge dart and that works well also scope
He said to leave the driver side in the stock position and move the passenger side up towards the rear end housing one leaf at a time, mine work best with the passenger side almost directly behind the rear end housing scope
Re: S/S Springs - Loose Front Spring Clamp [Re: Cab_Burge] #2620853
02/13/19 04:36 PM
02/13/19 04:36 PM
Toronto, Ontario, Canada
johndart Offline
johndart  Offline
Would this be with s/s spring by it's self or does it apply to s/s with Caltracs too?
Re: S/S Springs - Loose Front Spring Clamp [Re: johndart] #2620922
02/13/19 08:06 PM
02/13/19 08:06 PM
Calvert doesn't recommend using SS springs with his system scope
As far as leaving the clamps loose, do NOT do that tsk twocents
Re: S/S Springs - Loose Front Spring Clamp [Re: Cab_Burge] #2621230
02/14/19 12:59 PM
02/14/19 12:59 PM
moparx Offline
moparx  Offline
i like to use square top u-bolts in 5/16 or 3/8 diameter with 1/4"x1"wide straps [holes sized to the u-bolt diameter and strap length corresponding to include the size of the appropriate flat washer used].
sometimes though, square top u-bolts may be tough to find unless looking through a place like mcmaster-carr.
which ever way a guy clamps the springs, cut off excess bolt length and round the threaded ends. your arms and head will thank you !
beer
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2621476
02/15/19 12:01 AM
02/15/19 12:01 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The clamps are not actually clamps. They are alignment brackets to hold all the leafs in alignment with the main leaf.
On a totally separate note. Can not debate the fact some cars have improved their 60' time with a front segment clamped together. It basically makes the forward section a solid bar but their is a big downside to that procedure.
The leafs are meant to slide on each other. Picture an arched set of leafs, when they are compressed flat they bottom ones will grow longer. If they are clamped they are not allowed to slide. Fact is 4000lbs and a dip in the road will force them to slide but the friction set by the clamps will make the suspension have a memory. Push down and it will want to stay down, pull up and it will stay up.
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2621574
02/15/19 10:14 AM
02/15/19 10:14 AM
Locomotion Offline
Locomotion  Offline
Just keep an eye on clamp-to-sidewall clearance when installing/moving aftermarket clamps.
Re: S/S Springs - Loose Front Spring Clamp [Re: Mopar72Man] #2624374
02/21/19 08:20 PM
02/21/19 08:20 PM
Chicago
PurpleBeeper Offline
Chicago
There is some GREAT advice above. You can buy leaf spring clamps at most auto parts stores in the "truck suspension" section.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: S/S Springs - Loose Front Spring Clamp [Re: Locomotion] #2624718
02/22/19 02:48 PM
02/22/19 02:48 PM
moparx Offline
moparx  Offline
this one is VERY important, especially if you make your own using two bolts and two plates ! also, when doing so, round all the square edges. this not only makes them look better, it also protects the sidewall if it just "kisses".
unless you can clearly see mucho clearance, look at the sidewall after a few miles to see if it has developed any "shiny" areas near the clamp location[s].
beer
Re: S/S Springs - Loose Front Spring Clamp [Re: moparx] #2628180
03/03/19 05:40 AM
03/03/19 05:40 AM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
definitely add clamps as they suggested the those locations,
believe it or not I actually used some good heavy duty stainless hose clamps 8 years ago and they have held up so far,
thin, cheap and quick!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
