Re: A-body 8 1/4 questions : rear gear set swap
[Re: convx4]
#2620580
02/13/19 12:11 AM
02/13/19 12:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
2.45 and below uses a unique carrier, anything above uses a different carrier. I seriously doubt the 7mm thing though since they didn't do metric back then.
[Re: convx4]
#2620909
02/13/19 07:34 PM
02/13/19 07:34 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
IIRC, the issue you run into when going to the 3 series gears is the ring gear hits one small area of the case, and that can be ground out to clear.
[Re: convx4]
#2623171
02/19/19 01:05 AM
02/19/19 01:05 AM
slantzilla
Park Forest, IL
IIRC, the car bearing will fit on the truck carrier. I went through that on one I did.
