Re: Chrysler A999 Transmission
[Re: b_body_fan]
#2619593
02/10/19 11:51 PM
02/10/19 11:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
All A9xx series trans are related. the 904 is the /6 spec. the 998 the 318 spec. the 999 the 360 spec version. All versions can have a lock up converter.
As the number gets bigger the capacity gets greater.
So an A999 is the most beefed up production A904 variant available.
[Re: b_body_fan]
#2619622
02/11/19 12:39 AM
02/11/19 12:39 AM
Guitar Jones
A999 would have the 5 disc front clutch.
[Re: b_body_fan]
#2619624
02/11/19 12:41 AM
02/11/19 12:41 AM
RapidRobert
from "HP mopar" magazine: the best one is one from a 75 to 79 cordoba/coronet behind a 360 & it had a 5 clutch drum & a better pump compared to earlier ones & to avoid a lockup unit but I thought the LU's came later??? here is a link for some more info & I would Google it also. http://mmerlinn.com/catalog/lil_sis_4/tf_9nr/tf9nr010.htm EDIT found a note: LU started in 1978/& it is 26 splines/smooth end on tip of input shaft as opposed to splined all the way
[Re: b_body_fan]
#2620399
02/12/19 06:42 PM
02/12/19 06:42 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My Diplomat "AHB" Police packages came with A999 with lockup, but went into lockup later (seems to be about 10mph later), five clutches with HD parts, wide ratio. Which is pretty much what GuitarJones and RapidRobert wrote. Good trans really.
Facts are stubborn things.
[Re: Magnumguy]
#2620409
02/12/19 07:10 PM
02/12/19 07:10 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A999 is lockup, and some have a lower 1st gear ratio. The A-999 was introduced in '74, lockup didn't arrive until '78 and the lower gearset until '80.
[Re: Magnumguy]
#2626990
02/28/19 03:28 AM
02/28/19 03:28 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Fortunately, the lock up is hydraulic actuated, so it's easy to delay or eliminate. Are LU's low stall? I do remember the early hydraulic lock up converters. Some of them came on pretty early and you could really feel it. Seems to me we changed the spring in the hydraulic ones to change when it came in but its been a long time since I worked on a hydraulic one. Most of the ones I worked with were the electronic lock-up as I worked at a Dodge dealer from 1986 to 2011. I don't remember what year they started with the electronic lock up though but most of the ones I worked on were electronic lock up ? Ron
[Re: 383man]
#2627126
02/28/19 03:34 PM
02/28/19 03:34 PM
John_Kunkel
Rio Linda, CA
First year for the electronic lockup was '86.
