Re: Hemi spun main bearing
[Re: 8pack]
#2620309
02/12/19 04:35 PM
02/12/19 04:35 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
You need to figure out why that bearing spun so you can fix that so it won't do that again Which one spun? How much use, miles on it, before it broke? I've never heard of larger outside diameter main bearings, you will need to have the block fixed before using it again Do you have a really good machine shop to use? If not find one They may need to metal spray the bad bearing cap and the block so they can align hone it when done
[Re: 8pack]
#2621005
02/13/19 10:34 PM
02/13/19 10:34 PM
Posts: 2,674 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I agree with Cab. Hemi blocks don't have a reputation for spinning main bearings. I would want to know why it did it. Or we could be right back here next month with the same questions.
2011 Drag Pak Challenger
[Re: 8pack]
#2621013
02/13/19 10:53 PM
02/13/19 10:53 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Would like to see a few picture of what happened with the block and bearing and crank. Post some and you will likely get the answer or a direction you likely should go in to fix the problem. I agree with Cab and every one else does I would think. Need to find the problem before you can fix the problem.
1971 HEMI E BODY REGISTRY
[Re: 8pack]
#2623656
02/20/19 12:42 PM
02/20/19 12:42 PM
Posts: 289 Lowes
steve660
Lowes
If its an automatic i'd be checking if the converter is preloading the crank. Happens more than you think.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: DoubleD]
#2623771
02/20/19 04:23 PM
02/20/19 04:23 PM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
First thing I would check is how far the input shaft of the tranny goes into the crank - my guess is you are bottomed out against the crank - many aftermarket cranks are not drilled deep enough. This.
