Re: 383 Valve Covers
[Re: 6bblgt]
#2619851
02/11/19 03:56 PM
02/11/19 03:56 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
what side do you need?
[Re: JF_Moparts]
#2619911
02/11/19 05:54 PM
02/11/19 05:54 PM
6bblgt
Las Vegas, NV
pull of the oil fil cap narrow-lip "early" or wide-lip "late" I'll see what I have - what's wrong with yours?
[Re: JF_Moparts]
#2619933
02/11/19 06:47 PM
02/11/19 06:47 PM
Posts: 2,379 White Plains, NY
VCODE
White Plains, NY
Ok, will do.
Mine was leaking oil and I found a bunch of splits/cracks in the metal along the sides near the bolt holes. I'm seeing if a replacement can be found instead of trying to weld that thin metal. It was tightened down to much and caused the split holes. It looks like a 1970 Valve cover to me, but to be 100% you must take off oil cap like Dan said. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: JF_Moparts]
#2619934
02/11/19 06:56 PM
02/11/19 06:56 PM
Posts: 18,157 Mass
DAYCLONA
Mass
It looks like I need a new valve cover for my 1971 Roadrunner 383. I have the original factory covers.
Does anyone know what other years/engines used the same valve cover? I've never had to replace a factory valve cover and have no idea which ones to look for. Thanks. Buy a NEW set from AMD...
[Re: DAYCLONA]
#2619936
02/11/19 07:00 PM
02/11/19 07:00 PM
VCODE
White Plains, NY
Does anyone know what other years/engines used the same valve cover? I've never had to replace a factory valve cover and have no idea which ones to look for. Thanks. Buy a NEW set from AMD... Ask me how I know. Don't do that if you want them to fit. Holes are wrong, crease on top in stamping, oil cap is not clocked correct and does not fit tight. Bob
[Re: JF_Moparts]
#2619950
02/11/19 07:34 PM
02/11/19 07:34 PM
VCODE
White Plains, NY
That looks like a 1970 to early 71. Late 71 has a larger raised circle. Bob
[Re: VCODE]
#2619964
02/11/19 07:49 PM
02/11/19 07:49 PM
6bblgt
Las Vegas, NV
& if you notice the AMD RH valve cover doesn't have the same "divot" on the front of the passenger side
[Re: 6bblgt]
#2619970
02/11/19 08:07 PM
02/11/19 08:07 PM
VCODE
White Plains, NY
Dan, I think what AMD did was make a 70 only and a late 71 only The late 70 early 71 may have changed and they maybe did not make that one. See my picture of the stamping crease. Bob
[Re: JF_Moparts]
#2620006
02/11/19 09:25 PM
02/11/19 09:25 PM
VCODE
White Plains, NY
Yes, just looks a little different. Most at a local show will not notice.
