1969 plymouth fury disc brake conversion #2619533
02/10/19 09:02 PM
02/10/19 09:02 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
watching for a donor car-----but in the mean time i wonder if anyone has used 74-77 dodge van spindles rotors calipers with a front steer rack and pinion?
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619536
02/10/19 09:31 PM
02/10/19 09:31 PM
AndyF Online content
AndyF  Online Content
What spindles are you looking for? I have a couple sets of the '73 C body knuckles that people use for disc conversions.
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619578
02/10/19 11:12 PM
02/10/19 11:12 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
at this point not interested in piecing together the package---bob
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619614
02/11/19 12:28 AM
02/11/19 12:28 AM
Andrewh Offline
Andrewh  Offline
I have never heard of anyone using van spindles.
I know the rotors are the same, but why do you think the spindles will work?
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619617
02/11/19 12:33 AM
02/11/19 12:33 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Sounds like he wants to do a rack and pinion conversion.
Kevin
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619768
02/11/19 01:30 PM
02/11/19 01:30 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
i have looked at an illustration on line and the spindles look similar----the bearings and races are the same----ditto ball joints ----also correcto mundo on rack conversion----you get a bigger oil pan----maybe more room for full length headers on a 5.7 hemi conversion and the possibilty of coilover front.....
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619814
02/11/19 02:51 PM
02/11/19 02:51 PM
moparx Offline
moparx  Offline
were those vans front steer ? i can't remember.
beer
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619951
02/11/19 07:35 PM
02/11/19 07:35 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
i am going to do a pick a part run to verify------online diagram iffy...
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2619962
02/11/19 07:47 PM
02/11/19 07:47 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Going way back in the memory banks...It seems like the truck and/or van spindles can be used on the C body cars. I don't believe the spindles are exactly the same though. Some custom made parts or machining may be required. It has been a VERY long time since I've talked to anyone about this subject...so my memory could be wrong.
Re: 1969 plymouth fury disc brake conversion [Re: savoy64] #2620022
02/11/19 10:19 PM
02/11/19 10:19 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Vans and trucks are front steer, I have a friend who has a set for a 69' C Body. Spindle height from ball joint to ball joint is different from a truck IIRC.
I did a disc conversion on a 68' Sport Suburban 20+ years ago and used 74' or 75' C Body with a 60' or 61' New Yorker Lower ball joint IIRC
