904 OH tools needed #2619274
02/10/19 01:54 AM
02/10/19 01:54 AM
RapidRobert Offline OP
what do I need or fab for tools to overhaul a 904. other than slide hammering the pump out & the right type pliers for the big ring for the ext housing, what do I need for the clutch packs & anything else? thank you for your time.
Re: 904 OH tools needed [Re: RapidRobert] #2619275
02/10/19 02:03 AM
02/10/19 02:03 AM
CA
crackedback Offline
crackedback  Offline
CA
Don't need a slide hammer at all.
The rest is basic tool, even c clamps to compress the clutch spring.
Re: 904 OH tools needed [Re: RapidRobert] #2619278
02/10/19 02:14 AM
02/10/19 02:14 AM
PA
Scully Offline
Scully  Offline
PA
A chain with a screw pulls the pump out.
Re: 904 OH tools needed [Re: Scully] #2619306
02/10/19 10:53 AM
02/10/19 10:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I actually used a really long 3/8 bolt with a large impact socket(36mm for my jeep hubs) as a makeshift slide hammer and it pulled the pump real easy.
68 Barracuda Formula S 340
Re: 904 OH tools needed [Re: RapidRobert] #2619307
02/10/19 10:56 AM
02/10/19 10:56 AM
Guitar Jones Offline
You can make a slide hammer for the pump with some 3/8 threaded rod, a couple nuts and a 1/2" drive deep socket. I have a universal front clutch compressor I've used for years. I'll see if I can find a link for it.
Re: 904 OH tools needed [Re: RapidRobert] #2619311
02/10/19 11:17 AM
02/10/19 11:17 AM
Here is the tool. I bought this because I was doing a lot of different transmissions at the time and this has never failed to work for me.
compressor tool
This also looks useable and it's cheap.
cheap tool
Re: 904 OH tools needed [Re: Guitar Jones] #2619411
02/10/19 03:38 PM
02/10/19 03:38 PM
I think I have a slide hammer & I will try the C clamps & if no go I will go ahead & get the cheap(er) of the two eBay item, thanks guys!
Re: 904 OH tools needed [Re: RapidRobert] #2619435
02/10/19 04:37 PM
02/10/19 04:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Here's cheap compressor. Made it in 10 min. Piece of exhaust pipe that fits the spring retainer with a window for the snap ring pliers, 2 plates & a piece of allthread. All from scrap metal I had laying around.
Re: 904 OH tools needed [Re: RapidRobert] #2619455
02/10/19 05:30 PM
02/10/19 05:30 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Smaller (lb/in & lb/ft) torque wrenches, slide hammer (3/8" NC), pump alignment tool (big hose clamp), clutch spring compressor, asst. snap ring pliers and picks, feeler gauges & dial caliper, dial indicator, "shoe horn" tool to get the pistons in, tools to compress the servo springs are handy.
Re: 904 OH tools needed [Re: RapidRobert] #2619475
02/10/19 06:10 PM
02/10/19 06:10 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
If you have a steering wheel/harmonic puller kit take a couple bolts about 2" long and attach it to the yoke with some nuts.
Then use it and a vise to compress the clutch drum spring
Re: 904 OH tools needed [Re: RTSE4ME] #2619501
02/10/19 06:55 PM
02/10/19 06:55 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Works well if you don't have a tool that's the right size.
Re: 904 OH tools needed [Re: CMcAllister] #2619521
02/10/19 08:28 PM
02/10/19 08:28 PM
You guys are good! I'm ready to get on it.
Re: 904 OH tools needed [Re: RapidRobert] #2619564
02/10/19 10:43 PM
02/10/19 10:43 PM
I never used the pump alignment tool. I just put the loosely assembled pump into the empty trans case backwards without the o ring, started a bolt to keep it from rotating in the case then torqued the pump bolts.
Re: 904 OH tools needed [Re: Guitar Jones] #2619604
02/11/19 12:07 AM
02/11/19 12:07 AM
^^^ also noted.
Re: 904 OH tools needed [Re: RapidRobert] #2621536
02/15/19 03:29 AM
02/15/19 03:29 AM
CA
crackedback Offline
crackedback  Offline
CA
Don't need a single bolt or chain to get the pump out.
Stand it on the bellhousing, tap tailshaft. Usually falls right out.
Watch the how to rebuild a 727 video, it's in that too.
Re: 904 OH tools needed [Re: crackedback] #2621721
02/15/19 04:12 PM
02/15/19 04:12 PM
I'll watch it
Re: 904 OH tools needed [Re: crackedback] #2621770
02/15/19 05:56 PM
02/15/19 05:56 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
That might work, if the tailhousing was off of it, but everything in front of the output shaft would come along with it. And hit the floor if someone wasn't able to catch it. Sounds a little "rural" to me.
Re: 904 OH tools needed [Re: RapidRobert] #2621818
02/15/19 08:13 PM
02/15/19 08:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If the 904 pump housing is like a 727 just use a short chain and pry bar. I just use the two threaded holes in the housing to bolt the chain, then run a bar through the chain resting the end on the bell housing face. Give the bar a sharp pull and the pump housing will pop right out. Pretty simple, "rural", maybe but it's easy and fast.
Re: 904 OH tools needed [Re: CMcAllister] #2621985
02/16/19 02:10 AM
02/16/19 02:10 AM
A727Tflite Offline
A727Tflite  Offline
In a pinch this works if you first adjust the front band tight.
That holds the front clutch retainer and everything behind it.
Only thing that will come out then is the pump. And of course any fluid if you don’t drain the trans.
Re: 904 OH tools needed [Re: RapidRobert] #2622020
02/16/19 04:38 AM
02/16/19 04:38 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Tighten front band, find an old screwdriver, slide between band and case, against pump, tap it out. A vice and deep sockets works for the clutch spring. Valve spring compressor works on front servo cover. Snap ring pliers and a feeler gauge for clutch seal install is all you need. Guy that showed me how to rebuild the first time tapped on pump splines with a dead blow hammer while pulling on pump, slid right out. I did more tranny work with no tools than I do now that I have all the right tools. Simple trans to work on.
