Re: Testing an electric water temperature guage
[Re: jake4cars]
#2619404
02/10/19 03:28 PM
02/10/19 03:28 PM
RapidRobert
I would think with a 12V 110V house converter & you fed 12V to the gauge & the gauge negative terminal to the sender terminal and the sender body (threads) back to the neg wire on the converter that that would do it. EDIT I'd maybe wanna stick a thermometer into the water to check accuracy at different temps (up to boiling) to compare to the gauge readings but thats assuming the thermometer being used is accurate & the hardware store air temp one I have is WAY off (& a different one was too) so that is a FYI caveat.
[Re: jake4cars]
#2619961
02/11/19 07:47 PM
02/11/19 07:47 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
If it were me, I'd just use a car battery & boiling water. Water always boils at 212F (at sea level & slightly lower in the mountains)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
