Removing drip Rails
#2619234
02/09/19 11:32 PM
02/09/19 11:32 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Say on an E body, what's involved in losing the drip rails, for looks, aero, etc. Skill set needed? Any hidden land mines? Those that have done it, would you do it again, any regrets?
Re: Removing drip Rails
[Re: jcc]
#2619296
02/10/19 06:32 AM
02/10/19 06:32 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Sorry Nanket is wrong....the drip rails are where the upper roof skin is welded to the lower structure....when you cut of the drip rail the upper roof skin must be carefully rewelded to the lower structure.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: jcc]
#2619297
02/10/19 08:11 AM
02/10/19 08:11 AM
Posts: 5,830 ohio
ruderunner
ohio
Alternatively, one can trim off the lip for the stainless then fold the pinch weld down into the window opening.
Angry white pureblood male
[Re: moparx]
#2619370
02/10/19 02:38 PM
02/10/19 02:38 PM
jcc
Bitopia
A little more background, the car in question will be getting a full cage, and removing the roof makes that a lot easier to install, so I was wondering if this drip rail removal might be part of the project.
[Re: jcc]
#2619403
02/10/19 03:28 PM
02/10/19 03:28 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Definitely not a project for a novice welder since re-welding the top skin back on without warping it takes a lot of skill. Basically its not something that will make a difference on the race track either. Good luck though, if you decide to do it.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: jcc]
#2619452
02/10/19 05:24 PM
02/10/19 05:24 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
The drip rail on E body cars is the stainless trim. There is no drip rail made of the body sheet metal like A and B bodies. It is like a flat flange where the spot welds are.
[Re: NANKET]
#2619572
02/10/19 11:00 PM
02/10/19 11:00 PM
Posts: 10,136 A Red State
SNK-EYZ
A Red State
The drip rail on E body cars is the stainless trim. There is no drip rail made of the body sheet metal like A and B bodies. It is like a flat flange where the spot welds are. It's still called the drip rail on an E-Body, the trim is called the Drip Rail Molding.
