I purchased the Indy EZ heads at the Indy show and am starting on my 440 build.. I am on a very low budget due to other financial issues. So We pulled apart motor and looks like bearings were replace recently.. so those are good.. It has factory bore size 4.32.. I have a few questions. What type of cyl head gasket and who? Use studs or bolts for heads? and what cam u think I should run??? alum intake and demon carb with headers also 1.6 roller rockers. my cam selections were- XE284H or Mopar performance 509 purpleshaft. or Lunati Voodoo 226/234 @.50 .494/.513 lift. any help would be awesome.. thanks
