1972 15" x 7" Brushed Trim rings #2618771
02/08/19 06:03 PM
02/08/19 06:03 PM
Bradford, Ontario
Barrelhouse Offline OP
Bradford, Ontario
Hello i know true 15" x 7" trim rings are super hard to find and expensive if you do find them so who makes the most correct looking and fitting after market brushed rings that fit a 7" wide wheel.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2618838
02/08/19 09:11 PM
02/08/19 09:11 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The real answer is NO ONE. The only reproduction available is Wheel Vintiques which many people use but when compared aren't even close.
Ron
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2618857
02/08/19 10:12 PM
02/08/19 10:12 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
That huge outer lip is hideous!
25 years ago, I used to "cheat" with 14x7 Magnums and Ford brushed trim rings, but those went obsolete; wonder if there's a similar 15" Ford trim ring? They were closer to correct than the Chevy style.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2618867
02/08/19 10:45 PM
02/08/19 10:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The only option, other than hem is get a seat of polished rings and brush them your self.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2618914
02/09/19 01:37 AM
02/09/19 01:37 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Wheel Vintiques ones look hideous - I would never use them. WHY reproduce something like them when they are so far off?
(probably just "close" off the shelf ones made for multiple applications...)
Has anyone checked if there are 15" trim rings for GM or Ford older applications?
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619119
02/09/19 05:18 PM
02/09/19 05:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Wheel Vintiques must have changed to that ring. I bought some brushed from them years ago and they basically took the polished ring and brushed them lightly with steel wool or something. They didn`t look anything like those. They are ugly.
Re: 1972 15" x 7" Brushed Trim rings [Re: mopars4ever] #2619129
02/09/19 06:08 PM
02/09/19 06:08 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I have to concur. I bought a set of Wheel Vintiques 15x7 polished rings some time back, over 10 years ago. They don't have that excessive lip area at all. Main issue is the slightly tarnished or off color finish the have. But for a local show/ cruise night car they were A-OK.
I have a set of the Chrysler performance ones that were released to great anticipation than quickly were discontinued. I also have some original correct 15X7 ones needing resto. I have on my long list of things to do, is to find a good restorer and have 4 restored.
Along with decent trunk mats, good trim rings have always been on most everyone's most wanted list. Now we are finally getting the mats, so maybe there is hope someone will finally take on tooling rings!
Re: 1972 15" x 7" Brushed Trim rings [Re: Mastershake340] #2619142
02/09/19 06:32 PM
02/09/19 06:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally Posted By Mastershake340
I have to concur.
They goofed & re-did the 15" x 6.5" rings instead of the 7" rings.
Re: 1972 15" x 7" Brushed Trim rings [Re: Alaskan_TA] #2619154
02/09/19 07:11 PM
02/09/19 07:11 PM
Crook County, ILL
Crook County, ILL
I don't think that is correct Barry, could you remind me what the depth is of the correct 15X7s? I have some original 15x7 rings and years back when I first got the Chrysler performance repros I put one side to side with an original to see what differences I could spot. People were complaining about the new ones and as I recall it was due to some issues like contours and accent lines not being spot on. Plus the pricing of somewhere around $75-$85 each which people thought excessive back then in 2006-7 or whenever it was they finally got released.
Never heard any talk of incorrect 15x6.5 ring depth until now? You got me curious so I dug out one of my old original rings and eyeballing my tape measure looked to be maybe 3-1/8" deep. Went out in my cold garage and measured a repro installed on my T/A and it looked to be around 3-1/8". Weren't the 15x6.5s 2-3/4" or maybe it was 2-7/8" deep?
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619161
02/09/19 07:35 PM
02/09/19 07:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have some stored away, I'll try to dig them out later today.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619183
02/09/19 08:33 PM
02/09/19 08:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Original 15" x 7" trim ring at left & NOS 15" x 6.5" trim ring at right in both photos;
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619187
02/09/19 09:04 PM
02/09/19 09:04 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe Barry is correct, bought some 15 X 7s from Chrysler way back in the late 70s early 80s. Ordered another set some time later expecting 15 X 7s and they came in as 15 X 6 1/2. I still have them unused. Since then I have had a friend work on restoring 15X7 trim rings, taking them apart and taking dents out and then working on the curb rash. Not an easy job. The rings end up looking polished and then you have to put the brushed finish on them to make they look like the 1971s not the 1970 polished rings. There is a member on moparts that restores trim rings. Seen his work in some pictures and they are nicely done. It is a big job to do this and some trim rings just can not be done that have extreme damage. Price of doing them is not cheap but as of now there is no alternative that matches up to how these rings came from the factory. The 6 1/2 now rings I have will go on my Challenger one day with 15x61/2 rims on the front and a widened 6 1/2 to 12 inches wide on the back.
1971 HEMI E BODY REGISTRY
Re: 1972 15" x 7" Brushed Trim rings [Re: Alaskan_TA] #2619188
02/09/19 09:07 PM
02/09/19 09:07 PM
Crook County, ILL
Crook County, ILL
The 15x6.5 in your pictures does look to be around 2-3/4" deep, as I'd recalled.
The Mopar Performance repro 15x7 I measured on my car earlier today was a bit over 3" deep like the originals.
Re: 1972 15" x 7" Brushed Trim rings [Re: Alaskan_TA] #2619192
02/09/19 09:23 PM
02/09/19 09:23 PM
california
sbcjd Offline
sbcjd  Offline
california
The Mopar performance 15X7 trim rings issued in 2006-07 have the correct depth. I checked them with my original assembly line 15X7 rings.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619202
02/09/19 09:48 PM
02/09/19 09:48 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think you guys are mixing two stories.
Chrysler superseded the 15x7 trim ring with the 15x6 1/2. If you ordered the 15x7 part number and it came in a bag you got a 15x7 trim ring, if it came in a box you got a 15x6 1/2
When the Mopar Performance rings came out my brother was smart and bought a boat load of them.
As for getting rings restored I have 8 out with a guy now - he has had them for 14 months frown
Re: 1972 15" x 7" Brushed Trim rings [Re: Morty426] #2619217
02/09/19 10:48 PM
02/09/19 10:48 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Chris has it pretty much right on.
True first run deep 3461043 and 3461022 were replaced in the mid 70's, superceded to the 6.5 ring using the same part numbers and those were carried into the late 80's.
A true 15x7 ring carried this top label shown, no date and were bagged loose as stated if you ordered and received one from Chrysler.
If you ordered 4 as I did, they came bagged loose separated by brown wax paper.
The later 15x6.5 ring carried this different label with date and came boxed or sealed paper and plastic.
Could just be a co-incidence but any 6.5 brushed 022 ones that I got came in the box and 6.5 chrome 043's in the sealed paper/plastic.
I believe the 6.5 022's were discontinued before the 043's in 6.5's
Last picture is of the short lived 15x7 reproduction ring Hakim was involved with through Mopar performance in around 2006 hence the P on the label.
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619239
02/09/19 11:47 PM
02/09/19 11:47 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
How about something like these??
https://www.corvettecentral.com/67-68-rally-wheel-trim-ring-15-x-6-or-15-x-7-643197?returnurl=%2fsearch%3fcurrentsearchcategoryid%3d%26q%3dwheel%2btrim%2bring%26count%3d9
Helluva lot better looking than the Wheel Vintiques ones!
Re: 1972 15" x 7" Brushed Trim rings [Re: Sunroofcuda] #2619240
02/09/19 11:50 PM
02/09/19 11:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619245
02/09/19 11:58 PM
02/09/19 11:58 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
This looks pretty close too - 15" x 3" deep. It'll clip onto the Mopar wheels!
https://www.cokertire.com/accessories/trim-rings/15x3-o-e-m-style-trim-ring.html
Re: 1972 15" x 7" Brushed Trim rings [Re: Barrelhouse] #2619246
02/10/19 12:02 AM
02/10/19 12:02 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Another GM Rally - 15" x 3" from Speedway: https://www.speedwaymotors.com/Stainless-Steel-Beauty-Ring-for-15-Inch-GM-Rally-Wheel-3-Inch-Wide,73748.html
