where to get speical T bolt on dash #2618943
02/09/19 02:46 AM
02/09/19 02:46 AM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
In the rush of trying to help my friend work on his GTX, I ended up dropping the T shaped stud that holds the plastic GTX woodgrain panel above the glove box onto the metal dash frame. Does anyone know who reproduces these or where I can get one or even maybe two for him? I feel horrible that I did this and I want to make it right since I was the one who lost it. I believe there is one to the right of the instrument cluster as well that holds the woodgrain on that side also.
Thanks !
inherited a 69 roadrunner from my grand pop.
Re: where to get speical T bolt on dash [Re: fuelishnsilly] #2618963
02/09/19 05:42 AM
02/09/19 05:42 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Found this on my first search.....probably other vendors have it too? The "T" or mounting hardware is sold separately. Hope this is what you're looking for?
Mike
http://www.performancecargraphics.com/Dash_Stuff/Hardware/B-body_Hardware.htm
DASH FRAME HARDWARE
● Special screws to attach radio bezel to dash frame:
 1968-69 uses (3) screws; 1970 uses (4) screws
$1.00 ea.  Quantity One: $1.00 Two: $2.00 Three: $3.00 Four: $4.00   Year 1968-1969 1970  
● Special screws (4) to attach A/C dummy plates to dash frame
$4.00 a set 
● Special hardware for 1968-70 B-body Standard with
optional glove box and driver side plastic upper bezels:
The 1968 and 1969 thick, clear/black/silver woodgrain
bezels are extremely fragile in the area where this
hardware attaches them to the dash frame. A screw
bonded to a tiny plate, with a nut and plastic insert allows
tightening the bezel just snug, without cracking it. One of
these hardware assemblies is used on the driver side
bezel, and one on the glove box bezel. Some 1970
B-body standard black/woodgrain bezels may use
either one or two of these screws.
Re: where to get speical T bolt on dash [Re: fuelishnsilly] #2618970
02/09/19 09:26 AM
02/09/19 09:26 AM
Greenwood Lake, NY
Greenwood Lake, NY
I saw that but it said out of stock. I was wondering if there was another vendor.
