Page 3 of 3 1 2 3
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2618499
02/07/19 11:30 PM
02/07/19 11:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
ok... the piece of paper I have used never has being suctioned. I use the starter motor. Admision valve prevents the suction.
If there is suction will be also "exhaustion"... right ? well, the plug/paper is not being spitted out either on exhaust stroke. Just blows out when the comnpression stroke comes in. God... I have made it many times!!!
Its like the ohms law! the flow will go throught the less resistant path! having any kind of plug, air will leave and get in just throught the valves. The minimal amount of suction or exhaustin over the plug won't affect it having the valves in working order.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2618503
02/07/19 11:43 PM
02/07/19 11:43 PM
Kirkland, Washington
Pacnorthcuda Offline
Anyone else had problems with piston stop tools on wedge engines? The stop is at such an extreme angle, almost horizontal to the top of the piston, that the force of the piston can easily deflect the stop if the stop isn't REAL stiff and rigid and too much force is applied. Insert joke here.
Re: TOP DEAD CENTER TRICK [Re: NachoRT74] #2618504
02/07/19 11:44 PM
02/07/19 11:44 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It's the power stroke that will cause suction during down stroke with both valves closed.
If you don't believe it, go out in the garage, pull a plug, put your finger on the hole and crank it over.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2618559
02/08/19 05:27 AM
02/08/19 05:27 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The paper or the plug used was already blown out due the previous compresion stroke by then wink which is the goal on this smoke
Once again, come on! I have made it many times! And the paper ball has being bever sucked in! It is of course a bit bigger than the hole and even being able to, somehow, get threated into the hole
This is allmost becoming like the eternal ammeter/alt upgrade discussion... LOL, for lot of guys I'm crazy and I'm using my imagination inventing everything LOL
Re: TOP DEAD CENTER TRICK [Re: NachoRT74] #2618575
02/08/19 10:18 AM
02/08/19 10:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not sure if that was directed to me.
I have made no comment on whether your little paper wad or a plug would get sucked in. I have no idea the physical details of either. Frankly finding TDC is so easy I would have never thought of it as a trick.
But you are the one that implied that it was impossible to have suction because the intake valve was open. I think you said it twice. I simply pointed out that you were incorrect.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2618587
02/08/19 11:35 AM
02/08/19 11:35 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Seeing those spark plug thread whistles brings up the cheapskate idea of copying the expensive NASCAR cylinder compression ratio tester ($4700) cheaply.
Mount a “slide whistle” to spark plug threads,
pipe a steady air supply to it from a battery powered mattress inflator,
then use a smartphone microphone along with an APP
to measure the frequency of the low frequency sound at bottom dead center,
and the higher frequency sound at top dead center.
Re: TOP DEAD CENTER TRICK [Re: BSB67] #2618854
02/08/19 09:58 PM
02/08/19 09:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yes but no LOL. Actually being general.
yes, correct, but on this case after the plug was already spitted out wink. I meant because the plug won't be sucked on that moment because there is not a plug on that moment wink.
and still, I have made it many times installing a plug there without consider that and never have had anykind of plug made being sucked in
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2618877
02/08/19 11:32 PM
02/08/19 11:32 PM
Unless you happen to start the process at TDC on the compression/power stroke. Then....suck city.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2619114
02/09/19 04:56 PM
02/09/19 04:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ok, never it happened to me... I plugged on any time it was without pay attention to the stroke it was and it never happened to me. Maybe some time met the power stroke and it has NEVER happened to me
Page 3 of 3 1 2 3
