4 speed adapter plate...
#2617946
02/06/19 06:47 PM
02/06/19 06:47 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
OK guys, hear me out, im haveing a heck of a time finding a big block 4 speed bell housing for a truck that isnt 10 million dollars. I have a mill, I have the tools to make a adapter plate that goes from the 833 pattern on a car bell housing to the wide truck pattern. I was thinking of using 3/8 plate. Im not worried about spline contact, or clutch pivot stuff as I can make all that work with simple tools. Do you guys think Ill need a crank flange spacer to get the clutch and pressure plate correct or is 1/4 or 3/8 not enough to worry about.
Its a farm truck, and a ugly one at that, but I really want to use up some old 383 parts I have laying around.
Re: 4 speed adapter plate...
[Re: Moparnut426]
#2617967
02/06/19 07:37 PM
02/06/19 07:37 PM
Posts: 1,842 South Bend
John Brown
South Bend
If you also have a welder, I'd say you probably don't even need an adapter. Just weld on more material as needed, then mill off whatever you don't need.
[Re: Moparnut426]
#2617975
02/06/19 08:07 PM
02/06/19 08:07 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
How much larger is the truck transmission bolt pattern than the car pattern? Bell housing cast iron?
[Re: Moparnut426]
#2617980
02/06/19 08:18 PM
02/06/19 08:18 PM
Posts: 10,145 A Red State
SNK-EYZ
A Red State
The obvious question is exactly what truck transmission are you trying to bolt up to the big block?
That might help with trying to find a bellhousing.
[Re: Moparnut426]
#2618036
02/06/19 11:26 PM
02/06/19 11:26 PM
rowin4
Even a old lLakewood will set you back $1-3 hundred but you could drill /weld whatever onto it with no problem
[Re: Moparnut426]
#2618249
02/07/19 01:58 PM
02/07/19 01:58 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
It would be easy to make an adapter plate from 3/8" then you could use your mill to take some off the face of the bell to compensate for the adapter plate. You would just need to get some 7/16 countersunk bolts to mount the plate to a standard bell. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Moparnut426]
#2618270
02/07/19 02:37 PM
02/07/19 02:37 PM
rowin4
If this truck is used for ordinary driving and not like dump truck or pulling heavy equipment I would think the 1/4 or 3/8 plate would work . Setting back that thickness shouldn't affect the pilot bearing or throwout bearing but dimensions should be checked.
[Re: rowin4]
#2618574
02/08/19 10:05 AM
02/08/19 10:05 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Even a old lLakewood will set you back $1-3 hundred but you could drill /weld whatever onto it with no problem The new Lakewood(newer part number 15335) accepts the NP435 pattern. It's still expensive, but no fabricating necessary. I've had a few cast big block bells, sure wish I had held on to them.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Moparnut426]
#2618866
02/08/19 10:44 PM
02/08/19 10:44 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Your time must not be worth anything to be willing to do all of that work, those bellhousings usually run $200 from a lot of people. try a craigslist search via https://www.searchtempest.com/you can search nationally. Or put out a want ad, someone probably has one on the shelf and would be willing to let it go affordably. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
