DoctorDiff 11.7 Rear disc brake kit #2616828
02/04/19 01:03 PM
02/04/19 01:03 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Who here is running one of these kits? I'm interested to see if it will work with a 15x10 drag style wheel.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2616855
02/04/19 01:52 PM
02/04/19 01:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What wheel?
What backspacing?
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2616868
02/04/19 02:15 PM
02/04/19 02:15 PM
AndyF Offline
AndyF  Offline
It depends.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2616875
02/04/19 02:36 PM
02/04/19 02:36 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I can pick the wheel based on what will fit the brakes. I imagine 15x10 5.5" BS. I want to run a 10.5" slick. I'm completely open to both of your experiences.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2616946
02/04/19 05:14 PM
02/04/19 05:14 PM
AndyF Offline
AndyF  Offline
If you haven't purchased the wheels yet then I'd suggest using a 17 inch rim. There are a lot of drag radials and slicks for 17 inch rims. If you need a 15 inch rim for some reason then you'll just have to be very careful on the backspacing and/or the type of wheel. My 15 inch Centerlines wouldn't fit but they had a little more than the usual amount of backspacing. In my case the wheel was deep enough that it got to the back of the caliper and interfered with the banjo bolt or the other fitting. I don't recall which exactly but it wouldn't fit and there was no easy solution.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AndyF] #2616963
02/04/19 05:47 PM
02/04/19 05:47 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've seen the 17" wheels work on the LX platforms even in a DR style tire. I've seen 1.9 sixty foots but the truth of it is that for me, I just want to maintain some of the vintage look that I had before going to 18's. I wouldn't mind a 17" front runner to clear the 14" fronts but I'd like a 15" to actually have a sidewall. Plus, its a 4 speed so I'd like a stiff wall 26x10.5-15.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2617035
02/04/19 09:25 PM
02/04/19 09:25 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I'm running them and love them but on a +15 18x9.5 rim
Re: DoctorDiff 11.7 Rear disc brake kit [Re: dangina] #2617051
02/04/19 10:03 PM
02/04/19 10:03 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Pics of the overall?
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2617154
02/05/19 01:41 AM
02/05/19 01:41 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
15" Weld wheels will not clear the caliper.
I test fit a 15 x 10" Center-Line Warrior wheel with 5" of back-spacing. I assume an equivalent Auto-Drag wheel will also clear. You will run into clearance problems if your wheels have much more backspacing.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2617888
02/06/19 04:18 PM
02/06/19 04:18 PM
dangina Offline
dangina  Offline
i'm also running 3/4" hubcentric spacers
Re: DoctorDiff 11.7 Rear disc brake kit [Re: dangina] #2617896
02/06/19 04:37 PM
02/06/19 04:37 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
That looks great. I was hoping to get a set of those on the car without spacers. It would need to be like an ET 6 to clear without the spacers.
Re: DoctorDiff 11.7 Rear disc brake kit [Re: AlexP] #2618324
02/07/19 04:11 PM
02/07/19 04:11 PM
dangina Offline
dangina  Offline
I wish these rims came in a negative offset but +15 is as low as it goes
Re: DoctorDiff 11.7 Rear disc brake kit [Re: dangina] #2626209
02/26/19 08:01 AM
02/26/19 08:01 AM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
My weld racing alumastar 2.0 double beadlocks fit the 11.7 rear brake kit. They are 15x9.5, 4" B.S. Running a 29.5x10.5 mt
Re: DoctorDiff 11.7 Rear disc brake kit [Re: Jeremiah] #2627122
02/28/19 03:27 PM
02/28/19 03:27 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Thanks, that's exactly what I was looking for.
