Pedal placement #2617533
02/05/19 10:57 PM
02/05/19 10:57 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I have a new project that will be my next big build. It's a 35 Plymouth coupe. Plan is to use my 512 stroker motor, and maybe a 4 speed. Question is, is it better to mount the pedals under the dash, or up through the floor? Will up through the floor cause me trouble with exhaust and such? Thoughts?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Pedal placement [Re: rattler] #2617570
02/05/19 11:59 PM
02/05/19 11:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
A 35 Plymouth has a pretty narrow firewall. A power brake booster takes up a lot of space on a firewall, and will want to occupy some space the motor will want to occupy. I would recommend against using the small diameters brake boosters, I've not heard of many that did not experience issues with the small diameter boosters. If you can get by with a non-power brake master, that frees up a lot of firewall space, and I would want the master mounted on the firewall rather then under the floor. Installing 3 pedals between the trans tunnel, around the steering column, and keeping everything inside of the body at the firewall can add a lot of interesting challenges to the deal. Hopefully the 512 is offset towards the passenger side, and you have small feet.
Under the floor master cylinders require the pressure valves, which are not usually a big deal, just something else that could cause problems down the road. I don't like the master under the floor, they are a pita to fill. You are also limited to pedal position by the frame location, exhaust, and clutch linkage. There are some advantages, with the proper brackets, you can move the master towards the rear of the car more, and also closer to the frame rails, which may help with exhaust clutch linkage, and starter clearance.
I much prefer to hang the pedals off the firewall, but that might be just me. Gene
Re: Pedal placement [Re: rattler] #2617607
02/06/19 01:20 AM
02/06/19 01:20 AM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
I did the in-the-floor on my last project (460 '51 f1 automatic) to keep the firewall engine compartment clean. All my future projects will have under dash pedals with messy firewalls. It was and is a pain, not worth it IMO. REAL CRAPPY picture, the only one that I have of the brake pedal, well kind of.
Re: Pedal placement [Re: poorboy] #2618065
02/07/19 12:21 AM
02/07/19 12:21 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thanks Gene. No power brakes on this one. That motor doesn't pull enough vacuum.I'll probably go with a hydraulic throwout bearing too. That will help with the linkage issues.
Re: Pedal placement [Re: rattler] #2618325
02/07/19 04:12 PM
02/07/19 04:12 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
I always mount them on the firewall
Re: Pedal placement [Re: wannadrag] #2686370
08/10/19 10:13 PM
08/10/19 10:13 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
On my 31 Plymouth coupe, I used a Wilwood triple master race car setup that hangs under the dash, but keeps everything out of the way under the dash. One master is for the clutch, one is for the front brakes and one for the rear. It has an adjustable balance bar between the 2 brake master cylinders to mechanically adjust front/rear brake bias. I like it.
FOr the gas, I used a '64 Buick Riviera setup that has a nifty little firewall pass thru for the throttle arm. I cut it down to fit as needed, and welded a little foot pad on it. Very simple, compact and reliable.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Pedal placement [Re: rattler] #2686409
08/11/19 08:15 AM
08/11/19 08:15 AM
E
earlymopar Offline
earlymopar  Offline
E
I used a similar method to what HemiJoel used with the Wilwood under-dash setup but I used a 2-cylinder mount on my 37'. I also machined-off the Wilwood pedals that are cast into the pedal arms and I machined the arm to accept pedals that looked more correct for a 37' era car or pickup. There are also ways to use cylinders that do not have reservoirs and then use a remote reservoir (or multiple reservoirs) under the hood.
- EM
Re: Pedal placement [Re: earlymopar] #2686443
08/11/19 10:43 AM
08/11/19 10:43 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
speedway offers units at a more reasonable price than wilwood-------for circle track cars and hot rods----firewall mount and under floor mount...
Re: Pedal placement [Re: Hemi_Joel] #2686758
08/12/19 09:18 AM
08/12/19 09:18 AM
moparx Offline
moparx  Offline
joel, that's a trick tilt wheel mechanism you made ! up
beer
