67-72 A Body LCA sway bar tabs #2617392
02/05/19 05:25 PM
02/05/19 05:25 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Where can you find the weld on sway bar tabs?
Hotchkis lists ones for the 66-69 B Body
https://www.hotchkis.net/product/1966-69...partnoval=23366
And the 70-74 E-Body and 70-72 B Body
https://www.hotchkis.net/product/70-74-e...partnoval=23367
Has anyone used either of these or where can you buy them, if possible.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2617398
02/05/19 05:48 PM
02/05/19 05:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I know you can buy them, optionally, from Firm Feel when you buy the front sway bar kit, but I don't know if they sell them separate, an email might work.
Don't be the exception.
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2617400
02/05/19 05:52 PM
02/05/19 05:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I want to say this place has them???
http://www.bergmanautocraft.com/
http://www.bergmanautocraft.com/proddetail.php?prod=5-2350
Might want to make sure these are the correct style????
The Firm Feel ones work, but they don't look stock. Just an FYI if that matters to the OP.
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2617409
02/05/19 06:15 PM
02/05/19 06:15 PM
AndyF Offline
AndyF  Offline
I don't think anyone makes a correct looking reproduction weld on bracket. Hotchkis makes a nice weld on bracket while several other places provide a bolt on tab or a simple L shaped bracket. I looked into all of this a few weeks back and then decided to just buy some A body arms with the correct tabs on them.
Re: 67-72 A Body LCA sway bar tabs [Re: AndyF] #2617487
02/05/19 09:42 PM
02/05/19 09:42 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I agree but they are not easy to find. I have Jim (Rhinodart) looking in his stash. It's for a buddy and he only needs the Driver side. It's for a hot rod 71 Demon, so correctness is not a real necessity.
The Bergman and Hotchkis B body look to be the same. Even the pictures are the same.
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2617749
02/06/19 12:35 PM
02/06/19 12:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I e-mailed Peter about the application and he wrote me back and said they should work. I don't know if the shape is exactly the same as the picture is smallish.
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2619402
02/10/19 03:26 PM
02/10/19 03:26 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
These?
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2619858
02/11/19 04:06 PM
02/11/19 04:06 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Agree, those do not look like the factory tabs.
Re: 67-72 A Body LCA sway bar tabs [Re: Mattax] #2619867
02/11/19 04:15 PM
02/11/19 04:15 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The one's pictured in the ad are, 73-76 A body, also.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 67-72 A Body LCA sway bar tabs [Re: cdstl] #2620101
02/12/19 01:07 AM
02/12/19 01:07 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I'm sure your right. Those mount high.
Here's a pic from FABO showing the ones up through '72 with the curved attaching wings.
