Neon #2616463
02/03/19 03:41 PM
02/03/19 03:41 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Any Neon experts on here, that I can talk to on the phone? The problem is to drawn out to go back and forth in texting.
Re: Neon [Re: 71birdJ68] #2616571
02/03/19 07:57 PM
02/03/19 07:57 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
What's the general problem so I can tell if an area with which I've had to deal? Brakes? Suspension? Engine?
Re: Neon [Re: 71charger] #2616579
02/03/19 08:24 PM
02/03/19 08:24 PM
Morristown Tn.
Morristown Tn.
Factory springs
Re: Neon [Re: 71birdJ68] #2616588
02/03/19 08:45 PM
02/03/19 08:45 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Valve or strut
Re: Neon [Re: moparjim79] #2616596
02/03/19 09:14 PM
02/03/19 09:14 PM
Morristown Tn.
Morristown Tn.
I don't understand what you mean, I'm talking about just the spring. That's why I want to talk on the phone
Re: Neon [Re: 71birdJ68] #2616746
02/04/19 05:05 AM
02/04/19 05:05 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
He was trying to figure out if you're talking about engine valve springs or the suspension springs (on the struts).
More basic detail will help so that people will know what exactly you need help with.
It would be more apt to get someone who knows that particular problem to help you.
"Factory springs" is too vague to know how to help, there are many assorted springs on a car..
Re: Neon [Re: SNK-EYZ] #2616768
02/04/19 09:20 AM
02/04/19 09:20 AM
Morristown Tn.
Morristown Tn.
Sorry about that, suspension springs.
Re: Neon [Re: 71birdJ68] #2616796
02/04/19 12:19 PM
02/04/19 12:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not much to the springs.Either good or bad.Same with the strut springs.easy to just buy quick struts.Rears are easy also and not pricey.Rocky
Chrysler Firepower
Re: Neon [Re: therocks] #2616858
02/04/19 01:59 PM
02/04/19 01:59 PM
moparx Offline
moparx  Offline
rocky is right. if your springs are weak, or broke, the struts are on their last legs as well.
better to just buy the quick struts.
beer
Re: Neon [Re: moparx] #2616860
02/04/19 02:04 PM
02/04/19 02:04 PM
Morristown Tn.
Morristown Tn.
There are several different part numbers of factory springs and I was wanting to talk to someone that is versed on them, so I can get the right NOS springs.
Re: Neon [Re: 71birdJ68] #2616911
02/04/19 03:41 PM
02/04/19 03:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Unless you are doing something fancy just get OE type replacements.When we had the Cruiser I got quick struts etc from Rock Auto.Cheaper than my son who is a parts pro manager at Advacne could buy them.I did buy the monroes because I dodnt trust off brands.But did replace nephews GM cars with the off brands and no problems.Rocky
Chrysler Firepower
Re: Neon [Re: 71birdJ68] #2616914
02/04/19 03:49 PM
02/04/19 03:49 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The build record should be available from Chrysler if you provide the VIN and it will call out the springs by a three letter code. Or if your lucky the paper tags will still be on the springs with a part number but they usually fall off.
And to each their own, quick-struts are bottom of the barrel junk put together by equally dim individuals. Two out of three installations the ride quality was total crap upon autopsy teardown I found parts missing and/or installed backwards/upside down ect.
Re: Neon [Re: 71birdJ68] #2616933
02/04/19 04:53 PM
02/04/19 04:53 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I put Quick Struts on my '04 R/T because I only had a short amount of time before I had to go back overseas. I hated them. Fortunately, I saved the struts and springs. A couple of years later, when I was between overseas tours, I put Koni inserts into the original strut housings. Expensive, but worth it.
Re: Neon [Re: 71charger] #2616985
02/04/19 07:21 PM
02/04/19 07:21 PM
Morristown Tn.
Morristown Tn.
I have quick struts now and want to go back to factory, but there is more involved than I want to just keep going back and forth on here. That's why I'd like to talk on the phone. 10 minutes on the phone is better than two weeks on here.
Re: Neon [Re: 71birdJ68] #2617043
02/04/19 09:42 PM
02/04/19 09:42 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
There's a reason we want to go "back and forth" on here- so others have the information pertinent to the repair.
It wont take 2 weeks. Just take 10 minutes and type out what's going on.
Re: Neon [Re: moparjim79] #2617068
02/04/19 10:44 PM
02/04/19 10:44 PM
Morristown Tn.
Morristown Tn.
There are quite a few different part numbers and tag numbers and suspension codes that can apply. The specific springs for my car can't be found, so I'm trying to find springs as close as possible to what my car came with. Then there are the front springs where the factory had different spring rates between left and right according to equipment installed, so the same thing applies with the front.
Re: Neon [Re: 71birdJ68] #2617079
02/04/19 11:09 PM
02/04/19 11:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I dont know installed plenty of quicks at the shop and at home.Never had a problem I used Monroes.Did plenty just replacing the strut it self along with any parts that were bad.usually bearing plates and rubber components.Rocky
Chrysler Firepower
Re: Neon [Re: 71birdJ68] #2617106
02/04/19 11:46 PM
02/04/19 11:46 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Try eibach.com. call them and discuss what's closest to what you want and compare to what they have. You never explained what you wanted, a firm sporty ride or a cushy luxo ride. Not a lot of people are going to want to call and have a "10 minute" conversation, which usually turns into 2 hours. People are going to continue to chime in about how you need to rebuild your assemblies untilyou set the record straight.
Re: Neon [Re: 71birdJ68] #2617130
02/05/19 12:45 AM
02/05/19 12:45 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
You don't mention which model year you're working on, but for '04, SE, SXT, and R/T all had the same front spring, 5272609AB, and the same rear springs 5272283AB.
Re: Neon [Re: 71charger] #2617471
02/05/19 09:10 PM
02/05/19 09:10 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
My 2000 4 door ES, I installed Monroe Quick struts all the way around , but did not think the ride height was correct . So I ended up buying new rear springs part number 5272284AB, and installed them to the monroe strut and that made no change. I just accept the fact that these cars all ride a little high in the rear.
