Which 6 Pack Carb to Manifold Gasket #2616083
02/02/19 06:41 PM
02/02/19 06:41 PM
South San Francisco, Ca
70sixpkrt Offline OP
What is the best 6 Pack carb. to manifold gasket to use? I'm currently using the one ProMax sells.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Which 6 Pack Carb to Manifold Gasket [Re: 70sixpkrt] #2616092
02/02/19 06:56 PM
02/02/19 06:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can still get the original tan heavy cardboard from Mopar Performance,I use nothing else least of all the thin black fiber. !
Re: Which 6 Pack Carb to Manifold Gasket [Re: 70sixpkrt] #2616103
02/02/19 07:20 PM
02/02/19 07:20 PM
I haven't seen any differences in using the thick or thin ones, as long as the throttle plates are not warped and the intake manifold mounting surfaces are flat also scope
do NOT over tighten them tsk
Re: Which 6 Pack Carb to Manifold Gasket [Re: Cab_Burge] #2616213
02/02/19 11:47 PM
02/02/19 11:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is minor compared to most.
Re: Which 6 Pack Carb to Manifold Gasket [Re: 62maxwgn] #2616283
02/03/19 02:22 AM
02/03/19 02:22 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Superformance makes some nice re-useable Holley gaskets made from the best materials available.
Give Greg a call at Superformance gaskets and get some carb rebuild gaskets too.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Which 6 Pack Carb to Manifold Gasket [Re: 62maxwgn] #2616425
02/03/19 02:17 PM
02/03/19 02:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the cardboard type gasket in the photo is the best general purpose gasket for all 3 carbs. people have been known to put the gaskets on backwards and then wonder why the carbs don't work.
Re: Which 6 Pack Carb to Manifold Gasket [Re: 70sixpkrt] #2616438
02/03/19 02:48 PM
02/03/19 02:48 PM
I was thinking of using the Promax ones again or I might try the Superformance ones.
4-speed
3:54 Dana
