Re: 440 into a 66 Fury..motor mounts?
[Re: AeroMonte]
#2615931
02/02/19 01:08 PM
02/02/19 01:08 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
IIRC the SB mounts should work.Been a while since Ive done a swap on a C body.I know my 65 B body uses the same BB and SB.Rocky
Chrysler Firepower
[Re: therocks]
#2615933
02/02/19 01:10 PM
02/02/19 01:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
IIRC the SB mounts should work.Been a while since Ive done a swap on a C body.I know my 65 B body uses the same BB and SB.Rocky Think he's asking about the brackets, which aren't the same IIRC. http://engine-swaps.com/ seems to say the donors are '66-72 B, '70-74 E, '66-73 C-Body B/RB
[Re: NANKET]
#2616005
02/02/19 03:22 PM
02/02/19 03:22 PM
RapidRobert
^^^ Ding ding ding I do believe we have a winna.
[Re: AeroMonte]
#2616167
02/02/19 09:20 PM
02/02/19 09:20 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
The mounts and brackets from the 73 c body will work in the 66 they have the same subframe, while you are at it grab the disk brakes, brake booster and prop valve and upgrade the stopping of your Fury
[Re: AeroMonte]
#2616264
02/03/19 01:16 AM
02/03/19 01:16 AM
modelmakerinc
They are discontinued BFG drag radials 345-55-15. About 13" of tread, another 4" of side bulge mounted on 12" wheels.
It was mini-tubbed and SS springs inboarded.
[Re: AeroMonte]
#2616324
02/03/19 09:56 AM
02/03/19 09:56 AM
therocks
Niles , Ohio
One bad looking Fury 65 to 68 were some of the best looking made to me.Rocky
Chrysler Firepower
[Re: NANKET]
#2616856
02/04/19 01:53 PM
02/04/19 01:53 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The engine brackets are different from SB to BB. The rubber mounts appear the same.
The subframe mount stands in the car are the same. "If" 66 K member is the same as 65,the driver side bracket top bolt hole goes to a threaded boss on the front of the block.
[Re: AeroMonte]
#2616878
02/04/19 02:41 PM
02/04/19 02:41 PM
modelmakerinc
65 is different, 66 through 73 are the same subframe, the C-bodies don't have a K-frame.
Like what was said, the engine blocks are like an big block, A body block with a threaded boss on the front of #1 cylinder. And use unique driver side engine mount brackets.
