440 thermostat housing won't seal ?
#261586
03/22/09 09:59 AM
03/22/09 09:59 AM
Posts: 3,820 New State
kidmopar
New State
I'm having an unbelievably tough time getting my 1970 440 thermostat housing to seal I've installed 2 different aluminum housings (one brand new repop from Frank Badalsen) a different pump housing using several different sealers (high-tac , rtv , silicone) I'm almost ready to try "J B Weld" or just arc weld it After 30+ years of working on these cars , I'm stumped! ANY help from our great Mopar forum will be much appreciated THANK YOU!
Re: 440 thermostat housing won't seal ?
[Re: mopars4ever]
#261590
03/22/09 10:10 AM
03/22/09 10:10 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I have a new mopar cast iron outlet if you need one. Mike
yes and ???
[Re: JohnRR]
#261591
03/22/09 10:13 AM
03/22/09 10:13 AM
Posts: 13,573 md
mopars4ever
md
yes and ???
Maybe it will work better than the aluminum one. Is that ok with you? Just checking.
[Re: mopars4ever]
#261592
03/22/09 10:14 AM
03/22/09 10:14 AM
JohnRR
U.S.S.A.
yes and ???
oops , I miised the IF YOU NEED one , that's I assumed this was ... a for sale post ...
[Re: JohnRR]
#261593
03/22/09 10:15 AM
03/22/09 10:15 AM
Posts: 13,573 md
mopars4ever
md
So far what help have you offered?
[Re: mopars4ever]
#261594
03/22/09 10:19 AM
03/22/09 10:19 AM
JohnRR
U.S.S.A.
One or both of your parts are possibly not flat ?
You obviously MISSED that while PIMPING your part which is not correct for the year car at least one of the posters has ...
I find these parts not FLAT , even a knew one , I run all of them over a piece of fine emory cloth on a surface plate in a figure 8 pattern till i get a clean gasket surface , never a problem sealing one unless its CHROME .
next
[Re: manymopars]
#261598
03/22/09 11:34 AM
03/22/09 11:34 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I'm still having problems with my Valiant. RT66Jim (member here) asked if maybe I'm having a problem with the radiator cap.
My problem is just sitting there it will seal. For 2 weeks with the cap on. I'll fire it up for the first time after putting in the thermostat housing back on and let it fun...no leak. Come out the next day and it's leaking. Once it starts leaking nothing that I do will stop it unless I take it back off. Take it off put another gasket, maybe another thermostat housing and it will do it again.
Well, after Jim said something about the radiator cap....after the first run of the motor getting up to operating temp....I'll let the motor cool down crack the cap and it hasn't leaked since.
There is still a problem.....for me. I shouldn't have to do that. But it's building too much pressure after I run for awhile and the cap isn't able to get rid of it I guess.
Anyways I'm saying this for maybe food for thought.........
Good luck, let us know some of the things that your try please?
Moparlee
[Re: kidmopar]
#261599
03/22/09 01:20 PM
03/22/09 01:20 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Just my $0.02:
Flat. Smooth. Clean. Has to be these.
Flat...the opposing surfaces are in contact at every point (or reasonably so). Excludes: warped, curvy, wavy, distorted by excessive torquing of fasteners, etc. Cast iron resists all of these better than aluminum or steel plate. Check in many directions with a true straight edge and 0.001" "feeler" gauge. Or against a surface plate. Or using machinists layout blue. Or even maybe using an extremely thin film of light oil.
Smooth...no nicks, scratches, gouges, pitting, etc. that connect the coolant with outside. The pressure of the hot coolant is constant when the engine is running. Even a tiny channel will eventually give the coolant a way to get through. Gaskets, sealers, etc can only do so much if the parts don't fit or aren't smooth and clean. Yes; epoxy it on and it probably won't leak, although if they are mismatched, even epoxy might give up after a while. Things that don't fit will vibrate at different frequencies and in different modes when clamped together.
Clean. If its smooth it should be clean.
oops forgot one: if its cracked somewhere, it may not be leaking at the joint. tiny crack can seep and be real hard to find...
Sorry for the long...hope it helps...good luck, I know it can be frustrating.
[Re: TJP]
#2895416
03/03/21 10:11 PM
03/03/21 10:11 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Like many I have tried all the tricks trying to get a stock housing (both used and new) to seal including having a machine shop check and mill both surfaces. Some attempts lasted longer than others but they all eventually leaked. Thankfully the car is not a stock type vehicle so I spend a little extra $$ and bought this billet aluminum O ringed housing and have never had a leak issue since (4 years now) I've had the housing off a few times and it has been leak free every time even with the same O ring and never use any sealant. Somebody should make a stock looking T stat housing with an O ring. https://www.summitracing.com/parts/bsp-90820
