CompCam lifter issue #2615321
01/31/19 10:51 PM
01/31/19 10:51 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Having a freshly built 440 i am having an issue with clatter with my CompCam hydraulic roller lifters. The lifters bleed off quickly and I wondered if anyone else has had problems with their lifters and how they resoved it? I have a high pressure oil pump. The solid pushrods were also bought from CompCams. We have checked everything possible, including another oil pump, and the clatter still occurs. CompCams said the lifters oil through the lifter band but not sure how that would happen as there are no oiling holes. Educate me please.
Re: CompCam lifter issue [Re: gregok] #2615335
01/31/19 11:16 PM
01/31/19 11:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So there are no holes at all on the body of the lifter? Are you positive you do not have solid lifters? Some Comp hydraulic cams have aggressive ramp profiles that will always make noise no matter what you do.
Gus beer
64 Plymouth Savoy
Dana 60
Re: CompCam lifter issue [Re: fourgearsavoy] #2615406
02/01/19 01:19 AM
02/01/19 01:19 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
No holes, not solid lifters.
Re: CompCam lifter issue [Re: gregok] #2615569
02/01/19 01:42 PM
02/01/19 01:42 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If there are no holes in the body, how is the hydraulic lifter getting an oil supply? I don't know if these are the Comp hydraulic rollers you are using but I see a hole.
https://www.ebay.com/itm/COMP-Cams-Pro-M...2-/392188611229
Re: CompCam lifter issue [Re: 6PakBee] #2615710
02/01/19 08:34 PM
02/01/19 08:34 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Yep thats them but don’t believe the holes are oil ports I think they hold the shaft for the roller.
Re: CompCam lifter issue [Re: gregok] #2615740
02/01/19 10:03 PM
02/01/19 10:03 PM
A727Tflite Offline
A727Tflite  Offline
Look closely at the picture in the link.
Looks like a very small hole at the top of the groove - on the side - in that image.
Two images added just for reference regarding possible location of the feed hole.
Re: CompCam lifter issue [Re: A727Tflite] #2615831
02/02/19 01:34 AM
02/02/19 01:34 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
hope this helps Transman......are these the holes that are being searched?
Re: CompCam lifter issue [Re: A727Tflite] #2615848
02/02/19 02:13 AM
02/02/19 02:13 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
The set I have do not have those holes. I have sent them back in for inspection and will see what they find.
Re: CompCam lifter issue [Re: gregok] #2615960
02/02/19 02:07 PM
02/02/19 02:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Sounds like a set of solid rollers. Please let us know how this turns out.
Re: CompCam lifter issue [Re: gregok] #2622405
02/17/19 01:22 AM
02/17/19 01:22 AM
A727Tflite Offline
A727Tflite  Offline
Any word yet on those holes missing?
Re: CompCam lifter issue [Re: fourgearsavoy] #2622549
02/17/19 03:20 PM
02/17/19 03:20 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Gus beer
Mine has a Comp retrofit roller kit in it. XR280HR. Sounds like a sewing machine. I was told it's normal. Haven't had any problems with the motor and revs to 6k without any issues.
