Re: carb and maniflod recomdations
[Re: Kippy]
#2614705
01/30/19 07:09 PM
01/30/19 07:09 PM
RapidRobert
Welcome aboard! I would suggest any dual plane intake (its a non wearing item/if the side flanges are flat/good idea to have it checked) that you can get a good deal on & an Eddy 1406 (600 CFM) & get the strip kit for it. I see em regularly on www.forabodiesonly.com for $150 ish used.
[Re: Kippy]
#2614807
01/30/19 11:01 PM
01/30/19 11:01 PM
Posts: 12,277 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Go with the 650 Street Demon. This review is for the 750, but the 650 is the same carb save for the primaries. And the test is done by Steve Dulcich. https://www.hotrod.com/articles/street-demon-750-carb-review/Here is a back to back dyno test between a 650 CarterBrock and a 650 Street Demon. https://www.youtube.com/watch?v=YNAlVFtUFL4And there are many, many more tests on Youtube on the Street Demon. The CarterBrocks are decent enough carbs, but their tunes are terribly out dated. The Street Demons have a very good tune for mild street cars and have several important design features that the CarterBrocks do not. Do some research and I bet you'll find that the Street Demon is simply a better OOTB carb for your application.
Master, again and still
[Re: DaveRS23]
#2614829
01/30/19 11:47 PM
01/30/19 11:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Go with the 650 Street Demon. This review is for the 750, but the 650 is the same carb save for the primaries. And the test is done by Steve Dulcich. https://www.hotrod.com/articles/street-demon-750-carb-review/Here is a back to back dyno test between a 650 CarterBrock and a 650 Street Demon. https://www.youtube.com/watch?v=YNAlVFtUFL4And there are many, many more tests on Youtube on the Street Demon. The CarterBrocks are decent enough carbs, but their tunes are terribly out dated. The Street Demons have a very good tune for mild street cars and have several important design features that the CarterBrocks do not. Do some research and I bet you'll find that the Street Demon is simply a better OOTB carb for your application. If you don't bother to tune any carb OOTB for your setup why bother at all? May as well sell it and drive a KIA
[Re: Kippy]
#2614845
01/31/19 12:33 AM
01/31/19 12:33 AM
RapidRobert
I was thinking of using a Eldelbrock Performer manifold 2186. there's on one FABO right now for $95 (shipped). Cant beat that!
[Re: Exit1965]
#2615295
01/31/19 09:51 PM
01/31/19 09:51 PM
Posts: 4,319 Prospect, PA
BSB67
Prospect, PA
I'd recommend a performer RPM intake. The performer is considered a stock replacement, but the RPM makes more power and torque pretty much every RPM you'd be driving it. For carbs, I just bought Summit's brand 600 carb. Has great features and great reviews, and runs good on my stuff totally out of the box, I only adjusted the idle speed. This is incorrect. Its not even close to stock. The power cross over between the Performer and the RPM is probably 400 hp. The OP won't even be close to that.
[Re: Supercuda]
#2615298
01/31/19 09:58 PM
01/31/19 09:58 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Go with the 650 Street Demon. This review is for the 750, but the 650 is the same carb save for the primaries. And the test is done by Steve Dulcich. https://www.hotrod.com/articles/street-demon-750-carb-review/Here is a back to back dyno test between a 650 CarterBrock and a 650 Street Demon. https://www.youtube.com/watch?v=YNAlVFtUFL4And there are many, many more tests on Youtube on the Street Demon. The CarterBrocks are decent enough carbs, but their tunes are terribly out dated. The Street Demons have a very good tune for mild street cars and have several important design features that the CarterBrocks do not. Do some research and I bet you'll find that the Street Demon is simply a better OOTB carb for your application. If you don't bother to tune any carb OOTB for your setup why bother at all? May as well sell it and drive a KIA Well look who's here.
[Re: DaveRS23]
#2615315
01/31/19 10:43 PM
01/31/19 10:43 PM
Supercuda
About to go away
About to go away
up yours
Go with the 650 Street Demon. This review is for the 750, but the 650 is the same carb save for the primaries. And the test is done by Steve Dulcich. https://www.hotrod.com/articles/street-demon-750-carb-review/Here is a back to back dyno test between a 650 CarterBrock and a 650 Street Demon. https://www.youtube.com/watch?v=YNAlVFtUFL4And there are many, many more tests on Youtube on the Street Demon. The CarterBrocks are decent enough carbs, but their tunes are terribly out dated. The Street Demons have a very good tune for mild street cars and have several important design features that the CarterBrocks do not. Do some research and I bet you'll find that the Street Demon is simply a better OOTB carb for your application. If you don't bother to tune any carb OOTB for your setup why bother at all? May as well sell it and drive a KIA Well look who's here. the guy that can tune a carb?
[Re: Dcuda69]
#2615370
02/01/19 12:26 AM
02/01/19 12:26 AM
RapidRobert
A street dominator would be another good one & they are fairly cheap.
