Weird Torqueflite Issue
#2614019
01/29/19 01:54 PM
01/29/19 01:54 PM
Posts: 364 US
f2502011
US
Finally got everything dialed in or so I thought. Did great at first as far as downshifting into passing gear once I got everything adjusted right. Drove for the first time yesterday in a while, and it would downshift into passing gear, but once I came to a stop and then took off it wouldn't shift back up until I put it in neutral then back in drive and it would shift normal again. Any ideas? 70 T/A 340 727
1970 EK2 T/A 727
Re: Weird Torqueflite Issue
[Re: f2502011]
#2614022
01/29/19 01:58 PM
01/29/19 01:58 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
[Re: Guitar Jones]
#2614030
01/29/19 02:14 PM
01/29/19 02:14 PM
Posts: 364 US
f2502011
US
How do you get it unstuck? Couldn't it be some kind of adjustment issue??
1970 EK2 T/A 727
[Re: f2502011]
#2614234
01/29/19 07:59 PM
01/29/19 07:59 PM
RapidRobert
I ain't diagnosing, just a FYI, the ext housing would need to come (back) off to get to the governor.
[Re: A727Tflite]
#2614330
01/29/19 11:02 PM
01/29/19 11:02 PM
Posts: 57 florida,usa
rdakota340
florida,usa
An old technician trick - get up to about 35-40 mph and throw in park for a second. No longer.
Then take it out of park real quick.
It will make an atrocious noise but the vibration will break the governor valve and weight loose. It won’t break parts, won’t damage anything if you do it quick.
If it doesn’t break loose then you have to pull the extension housing.
A fresh build like you say - probably got some dirt in it. Try this first it's worked plenty of times for me.
Turbos The Only Power Adder!
[Re: rdakota340]
#2614363
01/30/19 12:04 AM
01/30/19 12:04 AM
Posts: 364 US
f2502011
US
A fresh build like you say - probably got some dirt in it. Try this first it's worked plenty of times for me. I read about this on another forum, but I don't feel like this would result in anything but catastrophic failure. Awful sounds rarely if ever result in something positive.
1970 EK2 T/A 727
[Re: f2502011]
#2614374
01/30/19 12:18 AM
01/30/19 12:18 AM
Posts: 3,089 Michigan
A727Tflite
Everyone is entitled to their opinion.
Plenty of them here -
If you follow the instructions you won’t break anything.
[Re: A727Tflite]
#2614401
01/30/19 01:32 AM
01/30/19 01:32 AM
Posts: 364 US
f2502011
US
Who's instructions?
1970 EK2 T/A 727
[Re: stumpy]
#2614422
01/30/19 02:15 AM
01/30/19 02:15 AM
RapidRobert
I had heard about that (on here). I was thinking iirc that you only go partway & briefly into park (just enough to get it schreeching) to shock it loose. I dont remember anything about the speed.
[Re: stumpy]
#2614453
01/30/19 05:16 AM
01/30/19 05:16 AM
RapidRobert
Noted, that does make sense, thanks Stump.
[Re: f2502011]
#2614625
01/30/19 03:55 PM
01/30/19 03:55 PM
Posts: 25,903 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Problem could also be a stuck 2-3 shift valve; only way to tell is to hook up a test gauge to the governor pressure test port, if there is more than 2 psi after coming to a stop the problem is the governor. If not, it's a stick shift valve and the VB has to come out.
[Re: John_Kunkel]
#2614637
01/30/19 04:51 PM
01/30/19 04:51 PM
Posts: 364 US
f2502011
US
Problem could also be a stuck 2-3 shift valve; only way to tell is to hook up a test gauge to the governor pressure test port, if there is more than 2 psi after coming to a stop the problem is the governor. If not, it's a stick shift valve and the VB has to come out. Shifts normal if driving normal. Only did this after going into passing gear under full throttle then coming to a stop, starting off again and didn't upshift. Put in neutral or 1 or 2 then back in drive shifts normal again until repeating.
1970 EK2 T/A 727
[Re: f2502011]
#2614718
01/30/19 07:39 PM
01/30/19 07:39 PM
John_Kunkel
Rio Linda, CA
then coming to a stop, starting off again and didn't upshift. Question is, is it starting off on 1st after the stop and won't upshift or is it starting off in 3rd after the stop and won't upshift because it's already in top gear? Again, testing governor pressure will tell what's wrong.
[Re: John_Kunkel]
#2614727
01/30/19 07:55 PM
01/30/19 07:55 PM
Posts: 364 US
f2502011
US
It's for sure not 3rd. When it kicks down from 3rd into passing gear does it go to 2nd or 1st. Whatever it goes to when flooring it is what it starts off in and won't shift up until going to neutral then back to drive, driving normal and it's back to shifting normal. 1st, 2nd, 3rd as it should, stop, and starts off in 1st again and shifts like nothing is wrong till you floor it again and then it does the same thing.
1970 EK2 T/A 727
