Page 2 of 3 1 2 3
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610660
01/22/19 08:50 PM
01/22/19 08:50 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By GY3
Originally Posted By hemi-itis
I'D bet he would get into the 10's with a thumperized tater! up
Been 10's already...
Not w/o your bottle...
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610671
01/22/19 09:09 PM
01/22/19 09:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
popcorn
Rich H.
Esse Quam Videri
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610693
01/22/19 09:29 PM
01/22/19 09:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
With or without a power adder?I was thinking 10's on nutz work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Can you make a Dominator carb streetable? [Re: BradH] #2610724
01/22/19 10:33 PM
01/22/19 10:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By BradH
Anyone have experience w/ the HP-style 8082 1050? I'd heard that's more like the old-style 9375, in that it's a 2-circuit intended for a single 4-bbl application. It's not one of the fancy "new gen" billet series, though.
I’ve run a few motors with them.
They didn’t really behave much differently on the dyno than a 3 circuit.
The part throttle, light load throttle position still had the blades below the 3rd circuit discharge tubes, and most of the part throttle richness is coming thru the transfer slots.
That’s having the motor at about 3000rpm with a 50hp load on it.
My old school pre-HP 9375 3 circuit has pretty nice low speed manners with some TS restrictors and a primary metering block that accommodates a PV so it can run smaller main jetting.
Those early ones have a huge hole for the air bleed on the 3rd circuit, so it’s not that much of a player.
Re: Can you make a Dominator carb streetable? [Re: BradH] #2610732
01/22/19 10:41 PM
01/22/19 10:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had a bunch of different old style, non HP, 1050 CFM Dominators. I didn't try to tune the 8082 though and got rid of it to buy another List# 9375 up
I'm trying to remember another Holley 1050 CFM List number that I think may nave been 8086, 8680 or something close to that, I didn't like it either for foot brake drag racing down
I have tried and tested the later version HP-2 with the same List numbers and didn't like them either shruggy
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610735
01/22/19 10:47 PM
01/22/19 10:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ve never run any ootb, as from Holley 4500 carb that I felt had “good” low speed manners.
I have however tested many of them where the a/f ratio is in the 7’s or 8’s at light part throttle operation.
That’s a little tough on plugs.
Re: Can you make a Dominator carb streetable? [Re: BradH] #2610744
01/22/19 11:03 PM
01/22/19 11:03 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Did 100 mph in the 1/8th on a below sea level morning...Unfortunately at an 1/8 mile track. bawling
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610780
01/22/19 11:50 PM
01/22/19 11:50 PM
BradH Offline
BradH  Offline
You're about 10.9x MPH, but I don't think you have 10.9x 60-ft times.
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610781
01/22/19 11:51 PM
01/22/19 11:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
mine runs alright on the street for a daily , mine is the newer sportsman aluminium unit .
You will need to address T slot jetting , PVCR jetting and lower the idle feed restrictor .
A bit time consuming .
I did try an adapter - what a waste of time and money .
I feel , my experience , that whilst a 4500 is better than a 4150 if your heads are the restriction you may not see a big gain . I picked up more consistency with cnc stealths and 4500 carb/intake but less than a 1/10th . Put TF270s on and picked up just over 1/4 second , same intake and carb .
Oh and fuel consumption on street and strip went south with the 4500 , but I accept that trade off for the et and mph gain
Hey its a race car I drive daily
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610880
01/23/19 04:01 AM
01/23/19 04:01 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
A ThumperCarbs 1050 Dominator on my 408 was worth 15hp on the dyno over an OOTB QF 950, but, picked up 6mph and .400 in the 1/4mi. Dom tests each carb and they are right when you get them. Mine got 15 mpg and cruised no problem. Excellent cold starts to boot. That carb is for sale - $1,000 + shipping. I am buying another for the new engine!
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610890
01/23/19 04:48 AM
01/23/19 04:48 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Years and years ago I had a '66 GT Dart with a 9375 out of the box dominator and a 528 wedge. It run and I drove the car, but had some problems with the plug life. And the engine always felt a little lazy or "heavy" with the throttle response. It run well at full throttle though running 10.0's in the 1/4.
Then a friend of mine wanted to borrow the car, trying to get it in to 9's. He made some changes, used race gas, removed the exhaust and most importantly changed the carb. It was one out of a pro stocker tunnel ram and with the change the engine changed like night and day. It had a very crisp throttle response, a totally diffrent animal. He didn't get the 9 though, running 0.05 under my best so far and ending with 10.002..
Anyway, the carb was built by Chuck Nuytten, so I contacted him and asked if he could make me a pro street dominator, which he did. Probably one of my best purchases, got the crisp throttle response, great mileage, clean plugs etc etc. Got over 11 mpg on the highway and about 8 in the city. Doesn't sound like much, but the car had 4.10 gears and the engine was dynoed making 780 hp.
So, it definitely can be done.
Plynouth VIP '67 TT IC EFI
Re: Can you make a Dominator carb streetable? [Re: GY3] #2610974
01/23/19 12:40 PM
01/23/19 12:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive run a 1050 on the street for at least 15 years.Idles a bit high with the radical cam and 12.5 pistons but runs good.Plugs stay clean and havent fouled any in years.Best plugs are NGKs in my opinion.Rocky
Chrysler Firepower
Re: Can you make a Dominator carb streetable? [Re: BradH] #2613250
01/27/19 10:50 PM
01/27/19 10:50 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Originally Posted By Cab_Burge
Originally Posted By AndyF
Originally Posted By dthemi
Make sure its 3 circuit.
I'd never recommend a 3 circuit for the street...
iagree
... Dominic, Thumper Dart,760-900-3895, can fix them up for anyone wanting to drive a 3 circuit on the street up
Yeah, but they're not 3-circuits any longer once he's gone through 'em. laugh2
I’ve built a few 8082’s. Like stated they all need transfer slot restrictions. The newer ones have smaller ifr’s but they are in the high position. Old ones need to be converted to annular boosters. They are great carbs on 500 cubes on the street.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Can you make a Dominator carb streetable? [Re: GY3] #2613279
01/27/19 11:47 PM
01/27/19 11:47 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Depends on how streetable lol I ran this hemi with a roller and pair of worked 1050s on 93 pump gas on street. I loved it
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Can you make a Dominator carb streetable? [Re: GY3] #2613280
01/27/19 11:48 PM
01/27/19 11:48 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
1971 charger
Re: Can you make a Dominator carb streetable? [Re: toplescuda] #2613287
01/28/19 12:03 AM
01/28/19 12:03 AM
Washington
madscientist Offline
Washington
2 carbs and 2 mags. Can't beat that!
Re: Can you make a Dominator carb streetable? [Re: GY3] #2613430
01/28/19 11:26 AM
01/28/19 11:26 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Well the "mags" were empty. A med 7al2 a crank trigger. 2 could
were used. The "mags" were just the pointer
Both did fire thou
1971 charger
Re: Can you make a Dominator carb streetable? [Re: GY3] #2613431
01/28/19 11:29 AM
01/28/19 11:29 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
1971 charger
Re: Can you make a Dominator carb streetable? [Re: toplescuda] #2613804
01/29/19 12:56 AM
01/29/19 12:56 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I ran a pair of QFT 1150 Dominators on the street with no issue.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Can you make a Dominator carb streetable? [Re: GY3] #2613826
01/29/19 01:57 AM
01/29/19 01:57 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Well, all I can say is a 3 circuit has been many times over for me the only way to smooth out the transitions for part throttle, and smooth transition. Like someone else said transfer is the problem. Of course you have to work on every aspect of them no matter. You just run out of options with 2 circuit.
As for them gas washing cylinders driving them, that would for sure be an out of the ball park, out of wack carb.
Blowers, and 2 4 tunnel rams make them easier to manage for street driving. A single 4 is the hardest to make work smoothly. Softer signal makes them react more smoothly. Big signal on a single is great for the track but hard to soften on the street. Again, assuming we're talking about something with almost no vac.
The biggest disasters of Doms on the street, is when they're on small cam engines with tons of vac, that they don't belong on in the first place.
Page 2 of 3 1 2 3
