Cylinder scratches #2613126
01/27/19 06:19 PM
01/27/19 06:19 PM
69cornetr/t
69cornetr/t
Well I have my opinion but I want to hear from people that know. Check out these scratches tell me what made them they are in all cylinders but this one caught my eye that alerted me to the rest. There is brown in the scratches, kinda of a mixture of nasty oil condensation and rust but it wipes off. The engine has been sitting awhile. Now, I can't hardly feel them with my fingernail, but I can with my finger.
Re: Cylinder scratches [Re: ] #2613137
01/27/19 06:36 PM
01/27/19 06:36 PM
Washington
madscientist Offline
Washington
Pull it apart, clean it, dingle berry hone it (lightly) and run it. Measure the clearances and make sure the are correct while you're in there.
Re: Cylinder scratches [Re: ] #2613141
01/27/19 06:41 PM
01/27/19 06:41 PM
P
Porter67 Offline
Porter67  Offline
P
Look like old grey forged trw-s or such, id have to guess your .005 isnt enough, more like .008-.009 or better.
Re: Cylinder scratches [Re: ] #2613153
01/27/19 07:09 PM
01/27/19 07:09 PM
69cornetr/t
69cornetr/t
Ya kinda confirms what I was thinking.
Re: Cylinder scratches [Re: Porter67] #2613155
01/27/19 07:13 PM
01/27/19 07:13 PM
69cornetr/t
69cornetr/t
Pretty good eye you are correct on the pistons
Re: Cylinder scratches [Re: ] #2613159
01/27/19 07:18 PM
01/27/19 07:18 PM
69cornetr/t
69cornetr/t
Really think it's necessary to tear down and rehone and regap? It's got a 1000 miles on it,but they are quarter mIle hard miles nothing above 6000. In my mind I probably should but I just wanted to avoid that.I need to hear some nonbiased opinions
Re: Cylinder scratches [Re: ] #2613171
01/27/19 08:12 PM
01/27/19 08:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By 69cornetr/t
Really think it's necessary to tear down and rehone and regap? ... In my mind I probably should but I just wanted to avoid that.I need to hear some nonbiased opinions
Non-biased opinion: It's ugly in there and should be torn down and dealt with.
However, that's obviously not the answer you want to hear.
Re: Cylinder scratches [Re: ] #2613177
01/27/19 08:24 PM
01/27/19 08:24 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Your oil isn't hot enough before beating on it
Re: Cylinder scratches [Re: Porter67] #2613190
01/27/19 08:45 PM
01/27/19 08:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Those skirts are not like the newer TRW and speed Pro forged 440 pistons, they looklike the original forged 426 M.W TRW pistons shruggy
Did you gap the rings and deburr the ring ends? If not you should have tsk If you did then those scratches maybe from junk suck into the cylinders and got stuck between the top of the pistons above the ring lands and cylinder walls scope
Re: Cylinder scratches [Re: ] #2613226
01/27/19 10:08 PM
01/27/19 10:08 PM
P
Porter67 Offline
Porter67  Offline
P
To me they look just like the trw replacements from the early 70-s.
OP. what motor is this? What do you know about the pistons.
Re: Cylinder scratches [Re: Porter67] #2613253
01/27/19 10:58 PM
01/27/19 10:58 PM
69cornetr/t
69cornetr/t
It's 68 440 I built it in the 80s, used trw pistons,l and used a ring filer and checked the gap inside a fresh bored 030 block. But the did sit a couple years at a time. I used to run it at the track. Damn good motor ran 12s in a challenger. Was just going to swap it to another car thought I'd take peek inside.Ring gap was dead nuts on when I put it together.chrome moly
Re: Cylinder scratches [Re: madscientist] #2613265
01/27/19 11:22 PM
01/27/19 11:22 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
I agree..... Freshen it and run the piss out of it...
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Cylinder scratches [Re: ] #2613278
01/27/19 11:45 PM
01/27/19 11:45 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've always thought it was pretty amazing how imperfect things can be and still function admitably well for what they are.
Myself I would hand hone or machine shop touch hone and re ring it, but.....If you don't, it will be just as good as it was. I'm more inclined to repair and improve things while they are apart.
Rich H.
Esse Quam Videri
Re: Cylinder scratches [Re: ] #2613334
01/28/19 01:49 AM
01/28/19 01:49 AM
I would have it honed on a good Sunnen honing machine with a torque plate to remove the scratches and make the cylinder round and seal good up twocents
Once you get the heads off you will be able to see more, sometimes things look a lot worse than they are shruggy work scope
How many runs on the motor and rings?
If more than 30 put new rings in it up
I don't like or use low tension oil rings any more unless the motor has a vacuum pump on it twocents
Please let us know what you find and decide to do thumbs
Re: Cylinder scratches [Re: ] #2613379
01/28/19 04:43 AM
01/28/19 04:43 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What weight oil and what is the coolant temp when staging the car?
Take it apart and check clearance.
Re: Cylinder scratches [Re: ] #2613402
01/28/19 09:50 AM
01/28/19 09:50 AM
69cornetr/t
69cornetr/t
20 50 @ 180 degrees , but it's a street engine now . I'll take the heads off and get a better look. But most likely i will take it apart and fix it right because it will always bug the [censored] out of me if don't . I'll see what my machinist says first.
Re: Cylinder scratches [Re: ] #2613419
01/28/19 10:43 AM
01/28/19 10:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If the scratches aren't deep with nothing protruding it is what it is. If it gets honed to true it up remove everything chances are the piston to wall could be excessive. What is the purpose of honeing and leave the scratches? Make it pretty?.
Looks like a low buck piece. I'd run it.
Doug
Re: Cylinder scratches [Re: ] #2613422
01/28/19 10:50 AM
01/28/19 10:50 AM
P
Porter67 Offline
Porter67  Offline
P
Could always hone it and spend a couple hundred bucks and get the skirts coated.
Re: Cylinder scratches [Re: dvw] #2613425
01/28/19 11:03 AM
01/28/19 11:03 AM
69cornetr/t
69cornetr/t
True Doug you make a good point
Re: Cylinder scratches [Re: ] #2613426
01/28/19 11:10 AM
01/28/19 11:10 AM
69cornetr/t
69cornetr/t
I'll take the heads off go from there and throw some trick flows on it and beat on it some more, and have fun, that's what it's all about for me
