Finish line rules #2613178
01/27/19 08:28 PM
01/27/19 08:28 PM
southeast ky
mills.mopar Offline OP
southeast ky
What are your local track rules on finish line racing? The rules as far as I can tell is kinda a grey area... Obviously if you cross the center line or hit the wall your disqualified. I've had pretty good success at times losing 10 mph or so on the Finnish line and have got some flack for some smoke off the front tires.. just wondering what is your opinion or your tracks opinion on the matter.
Thanks.
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Finish line rules [Re: mills.mopar] #2613184
01/27/19 08:37 PM
01/27/19 08:37 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
One of the Emmons brothers from Texas was thrown out of a Nat. event in Phoenix for "Excessive Braking". 120mph car. Evidently he was warned in Pomona two weeks before. Meanwhile Funny cars and Pro-Mods are bouncing off the wall at 250mph plus. Stupid rules if you ask me. Out of control is out of control. If you're not tossing a salad in the other guys lane there should be no penalty.
Re: Finish line rules [Re: mills.mopar] #2613186
01/27/19 08:38 PM
01/27/19 08:38 PM
NHRA will disqualify you for doing that unless your opponent does it worst scope
Is your local track a NHRA affiliate and insured with the same company with the same set of rules work
BTW, when you race at any track you have to use and follow their rules and you should know all of them to avoid conflict up scope
Re: Finish line rules [Re: mills.mopar] #2613193
01/27/19 08:57 PM
01/27/19 08:57 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I have seen the aftermath of excessive braking a couple of times with destroyed cars. It is just plain stupid to hit your brakes hard on the top end. Dial it hard cut a light and race it. If I were a race official at the top end any tire smoke or wobble you are gone.
Real Men shift for themselves
Re: Finish line rules [Re: mills.mopar] #2613194
01/27/19 08:58 PM
01/27/19 08:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You have to use common sense. You can definitely knock off some ET at the strip safely. Smoking the tires? Why would it be necessary? Personally I know well before the stripe if I'm going to get there early or late. Unless you set-up to bag a ton.
Doug
Re: Finish line rules [Re: mills.mopar] #2613197
01/27/19 09:01 PM
01/27/19 09:01 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Excessive braking (tire smoke) is most often is a first offence warning, second disqualification.
If you need to break that hard to stay under a dial you probably should dial a little tighter twocents
There have been many examples of racers looping, sliding into the wall or opponents lane trying scrub off speed too aggressively hence the rule.
other than that I can not think of any Finish line rules
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Finish line rules [Re: mills.mopar] #2613201
01/27/19 09:13 PM
01/27/19 09:13 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
NHRA has observers at the national events looking for all kinds of stuff. Excessive braking, pulling off safety equipment before you got off the track, funny blinking lights, etc. They're on a schedule and don't want to have to clean up a mess or have people get hurt. Local tracks and divisionals, luck of the draw. I've seen flat tires and wrecked cars from it. Kind of stupid, but people still do it. Guys like the 4 caliper rear brake kits for that so they don't slide the front tires.
Re: Finish line rules [Re: CMcAllister] #2613204
01/27/19 09:18 PM
01/27/19 09:18 PM
Byron, NY
Byron, NY
Originally Posted By CMcAllister
NHRA has observers at the national events looking for all kinds of stuff. pulling off safety equipment before you got off the track, funny blinking lights, etc.
Forgot about the safety equip stuff
'60 Willys CJ5
Re: Finish line rules [Re: mills.mopar] #2613221
01/27/19 10:02 PM
01/27/19 10:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
But sometimes , it can be tough.............
Re: Finish line rules [Re: mills.mopar] #2613223
01/27/19 10:04 PM
01/27/19 10:04 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Seriously , I am from the tighten up your package camp.......if I am trying to kill more than 8-10 m.p.h. , I already screwed up.
Re: Finish line rules [Re: tubtar] #2613264
01/27/19 11:21 PM
01/27/19 11:21 PM
southeast ky
southeast ky
The point of my post was not to start a poop show... I was just asking what your tracks rule was on the matter... Because the rules are very vague on the matter.
For those of you that say I'm stupid to "drive" the finish line, I would love to race you! You are the easy ones to load on the trailer....
Jeff.
68 dart
37 dodge coupe
71 challenger
Re: Finish line rules [Re: mills.mopar] #2613285
01/28/19 12:00 AM
01/28/19 12:00 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know that my local track has a rule, and there's no one down there all day watching for it. Most local places are probably the same. I watch some of the high dollar stuff that's live stream and there's some aggressive finish line braking seen there on occasion. I guess it's part of the game. A lot of different finish line strategies in use.
Re: Finish line rules [Re: mills.mopar] #2613288
01/28/19 12:05 AM
01/28/19 12:05 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Are cars required to have operational brake lights so whatever they are doing, its obvious to everybody?
Re: Finish line rules [Re: jcc] #2613296
01/28/19 12:17 AM
01/28/19 12:17 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nope!
Re: Finish line rules [Re: jcc] #2613297
01/28/19 12:18 AM
01/28/19 12:18 AM
southeast ky
southeast ky
As far as I know just one red "running" light. No functioning brake light.
68 dart
37 dodge coupe
71 challenger
Re: Finish line rules [Re: mills.mopar] #2613303
01/28/19 12:30 AM
01/28/19 12:30 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
"Great save"! "WOW! what a great job of driving and keeping it off the wall"! Like the pic of Tim Fletcher. Guy totally screwed the pooch and tossed a salad and got LUCKY! NOT a great driving job! If you're locking up the tires it's probably not so good. I will say that I have broken hats right off the wheel hitting the brakes too hard. Won a divisional with that broken hat as it happened rd. 4 and I got a bye to the final. Hurt my back too! If there's is tire smoke and sliding the car all tracks will warn you once and throw you out the next time because they will be watching you.
Re: Finish line rules [Re: mills.mopar] #2613328
01/28/19 01:23 AM
01/28/19 01:23 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What is "tossed a salad"?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Finish line rules [Re: mills.mopar] #2613330
01/28/19 01:32 AM
01/28/19 01:32 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
In Fletcher's case they claimed "brake malfunction".
Kid from my area got tossed at 4 cars at a national event for smoking the tires after the finish line and crossing lanes on a pass he won. Luckily the other car was already by him. He got excited and tossed it into reverse.
Re: Finish line rules [Re: mills.mopar] #2613331
01/28/19 01:36 AM
01/28/19 01:36 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I read through the entire post......I missed anyone calling anyone stupid.
I think the consensus is clear......if you smoke the fronts going through the lights , you are going to attract some official attention.
And it seems like most feel it is justified.
If you can " drive the finish line " and not smoke your front tires or veer into the wall , then you have done nothing wrong from my chair.
Our approach has always been to run our race and let the chips fall where they may.
Whoever is in the other lane is not all that important.
Certainly not as important as they think.
Re: Finish line rules [Re: mills.mopar] #2613336
01/28/19 01:59 AM
01/28/19 01:59 AM
Jeff.
Which rules are vague, your track rules or NHRA rules?
As far as racing in brackets or handicap racing I'm your sugar daddy, when and where do we race devil whistling
I've been beat by .0004 (by John Calvert) and I've beat others by .0001 stirthepot devil
I have cut one perfect .400 light in super class racing also when division 7 race both S/P, Pro ET and both S/G and S/ST on a .400 pro tree boogie That was long before anyone had come out with the delay boxes we have and use today whistling grin
