big block engine mounts ? #2611624
01/24/19 04:01 PM
01/24/19 04:01 PM
moparx Offline OP
moparx  Offline OP
this will amuse many, but my old, feeble mind seems to have misplaced the answer.
so, are the [what i would call "upper"] block mounted part of the mount assembly the same [interchangeable] between C and B bodies ? this is for the biscuit type mount, NOT the spool type. TIA. [i don't know what i would do without you guys refreshing my memory ! biggrin]
beer
Re: big block engine mounts ? [Re: moparx] #2611638
01/24/19 04:21 PM
01/24/19 04:21 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: big block engine mounts ? [Re: moparx] #2611649
01/24/19 04:44 PM
01/24/19 04:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes, they are interchangeable.
My GTX was a bondoed up empty shell when I got it, I pulled my first 440 out of a '73 new yorker and (eventually) bolted it into the car using the C body brackets and mounts. It's a good thing they worked, I didn't have anything else to use at the time.
Rich H.
Esse Quam Videri
Re: big block engine mounts ? [Re: ZIPPY] #2612027
01/25/19 01:23 PM
01/25/19 01:23 PM
moparx Offline OP
moparx  Offline OP
greatly appreciated gents ! i "thought" they interchanged, but was not 100% sure.
you guys are the greatest ! immense thanks ! up bow
beer
