440 ARP main stud & stealth head ARP bolt torque ? #261130
03/21/09 07:44 PM
03/21/09 07:44 PM
Middletown , Ohio
DonnieLawson Offline OP
Middletown , Ohio
What should I torque my 505 stroked 440 block mains and stealth head to ?
ARP studs on the bottom end and ARP bolts on the Stealth heads ?
Thanks guys
Re: 440 ARP main stud & stealth head ARP bolt torque ? [Re: DonnieLawson] #261131
03/22/09 11:09 AM
03/22/09 11:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have mine torqued to ARP specs for the studs.On the heads my Stealths are at 65 with ARP lube.Just remember 3 steps on the heads.That and if you use oil the spec changes.My heads been on a year and lower end together for at least 6 years.I believe the studs were 85.But ARP has the specs.Rocky
Chrysler Firepower
Re: 440 ARP main stud & stealth head ARP bolt torque ? [Re: therocks] #261132
03/22/09 11:38 AM
03/22/09 11:38 AM
Middletown , Ohio
Middletown , Ohio
Ive found different info from different places , I'm finally putting the engine together , I only had to scrape the thrust bearing a little for clearance with the stroker kit.
Looks to 95 lbs from ARP on the mains
Thanks .
Anyone else ?
