HOW MUCH CAM AND SPRING WITH FACTORY R/T HEAD #2610814
01/23/19 01:24 AM
01/23/19 01:24 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
With a gasket match and pocket port with a set of R/T heads, how much cam and spring with the stock rockers? With a well sorted chassis , rear and trans, I'd like to be mid 11's or lower.
Re: HOW MUCH CAM AND SPRING WITH FACTORY R/T HEAD [Re: A/MP] #2610947
01/23/19 11:47 AM
01/23/19 11:47 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Dakota R/T, or something else?
Re: HOW MUCH CAM AND SPRING WITH FACTORY R/T HEAD [Re: A/MP] #2611157
01/23/19 06:10 PM
01/23/19 06:10 PM
Which year and motor R/T?
Re: HOW MUCH CAM AND SPRING WITH FACTORY R/T HEAD [Re: A/MP] #2611199
01/23/19 08:10 PM
01/23/19 08:10 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
93 or 4. I just have the heads and will either look for a Magnum block or re-purpose for a LA motor.
Re: HOW MUCH CAM AND SPRING WITH FACTORY R/T HEAD [Re: A/MP] #2611209
01/23/19 08:19 PM
01/23/19 08:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If its just some heads from 93 or 94 they are not R/T heads. The R/T head did not come out till around the time of the R/T truck (99) and even then the R/T head was just an aftermarket magnum head NOT the one issued on the R/T truck. The R/T head has R/T cast in big letters right on the side.
As for stock rockers I have started having the PR push through the rocker around .550 lift and 10,000 or so street miles and hughes 1110 or 1111 springs or something close to that number, whatever it was hughes recomended. I would say .500 or so lift and matching springs would last a very long time. With real R/T heads 11s should be no problem with a well sorted combo.
