70 challenger quarter panel patch panels #2610907
01/23/19 09:35 AM
01/23/19 09:35 AM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Does anyone sell a quarter panel patch panel for around the outer wheel well. I have small amounts of bubble around the outer edge quarter panel wheel wells. It is a convertible but I don't think it would matter for this application.
Thanks,
Mike.
1970 challenger convertible
Re: 70 challenger quarter panel patch panels [Re: mikeporp] #2613371
01/28/19 04:04 AM
01/28/19 04:04 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Nope: went thru this myself. Had to buy full qtr from amd. Not the full-full, but the other. Many times it's better (easier) to replace panel from body-line downward, then to attempt adding around wheelwell area. Besides: conv's were noted for rusting in that front-lower section of the qtr-panel.
Re: 70 challenger quarter panel patch panels [Re: mikeporp] #2613407
01/28/19 10:11 AM
01/28/19 10:11 AM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Ok...thanks
Re: 70 challenger quarter panel patch panels [Re: mikeporp] #2613913
01/29/19 10:19 AM
01/29/19 10:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did my 73 15 years ago. The only thing available were 1/2 quarters. Just cut the parts it needed. The area in front of the wheel us very close to the outer rocker. Mine had pine needles between the two panels. They had formed to a hard mass like OSB board. No way you could had removed them without cutting the panel. My panel showed very little rust from the outside. Glad I cut it. Still perfect today.
Doug
Re: 70 challenger quarter panel patch panels [Re: mikeporp] #2614405
01/30/19 01:40 AM
01/30/19 01:40 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I buy the goodmark skins from rockauto and cut what I need from them.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
