anybody use the right stuff detailing complete disc brake conversion kit for a 1969 roadrunner? the kit i have is 4 wheel disc, manual brakes with e-brakes. the problem i seem to be having is the brake cables that came with the kit will not work. i was able to make the factory long cable work on the passenger by trimming the spring but the short cable will not work. the cable they sent, the conduit is correct in length but the cable inside is too short. the factory cable, the conduit is too short to reach the bracket. i installed the calipers on the gas tank side of the axle but the instructions said you can mount them on either side. the stock cables would work if i mounted them on the front side of the axles but the problem with that application would put the bleeder screw down and not at the top. that's why i mounted them the way i did. any suggestions?
