Inline oil heater #2609570
01/20/19 10:05 PM
01/20/19 10:05 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
If you left a 400 watt inline oil heater plugged in overnight, how hot would the oil get?
There is no thermostat.
Can these oil heaters take running for excessive amounts of time.
My dart is in the trailer with antifreeze but temps are plummeting tonight.
I have a space heater in there but thought about plugging in my inline heater instead.
Re: Inline oil heater [Re: Sammy] #2609607
01/20/19 10:46 PM
01/20/19 10:46 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Inline ? ... or covering the pan or tank ? ..... don’t know if they still do it but some PS teams reportedly remove the oil and heat it externally
Re: Inline oil heater [Re: Sammy] #2609614
01/20/19 10:58 PM
01/20/19 10:58 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. I would imagine you would have a nice cozy Fire by the morning.. my oil tank gets scary hot after an hour.. that's 8 quarts
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Inline oil heater [Re: WHITEDART] #2609642
01/20/19 11:37 PM
01/20/19 11:37 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I agree with you but its 9 degrees in the trailer now.
I'm not sure if these heaters can work for extended periods of time.
Re: Inline oil heater [Re: Sammy] #2609678
01/21/19 12:36 AM
01/21/19 12:36 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You'll never get that oil hot enough. I was going to drain the water from the rad and block a few years ago after the season was over. The winter never came until late January. I had put off changing the water because of the mild weather. Wake up 2:30 AM and remember that I did not drain the motor. Next day, ice at the top of the rad and slush in the bottom. Panic!! Attached 2 block heaters and covered the motor with insulation. Checked every 2 hours. Next day, ice melted but the water was 34*. Dumped the water and pumped warmed antifreeze thru the motor. Let it circulate for 2 hours, thinking to melt any ice crystals that may have remained in pockets of the heads. Water temp 36*. Left the block heaters on overnight, water temp 34*. A cast iron block will always wick the heat to the ambient temp. If you prepped your motor before winter, than that cold cold oil means nothing unless you are trying to start it. I have 2 friends that change the oil to 0 W and they crank over the motor every week. As long as the water doesn't freeze, you are OK.
Re: Inline oil heater [Re: Sammy] #2609776
01/21/19 10:36 AM
01/21/19 10:36 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Heated on a big stove before being added to the crankcase: aero engines in 1914.
Leaving heavy oil in the car is harmless... until/unless you need to start it. Thick oil not only kills cranking speed, but when it starts it takes 3 weeks for the oil to reach that last bearing.
Boffin Emeritus
