1986 W150 tail light issue #2609175
01/20/19 12:02 AM
01/20/19 12:02 AM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
Having some lighting issues with my 86 w150. When you turn on the headlights the break light don't work and the tail lights don't come on. It's a 4 speed on when you put it in reverse the tail lights come on but not the back up lights. With the headlights off the brake and turn signals work as normal. Any ideas? Anyone know of an on line wiring diagram? Thanks in advance.
Re: 1986 W150 tail light issue [Re: Racer33] #2609184
01/20/19 12:18 AM
01/20/19 12:18 AM
see if www.mymopar.com has it & Google it. EDIT I think I would start at the headlight switch connector
Re: 1986 W150 tail light issue [Re: Racer33] #2609207
01/20/19 01:31 AM
01/20/19 01:31 AM
Texas
Moparmad Offline
Moparmad  Offline
Texas
I would check the blinker switch. I was having multiple problems st the same time. Looked at wiring diagram and almost every light on the truck went through the blinker switch. Changed it out and fixed all of the issues.
Mine was an earlier model(1975)so may not be wired the same. Worth checking the schematic.
Re: 1986 W150 tail light issue [Re: Racer33] #2609211
01/20/19 02:05 AM
01/20/19 02:05 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
look under the rear of the bed near the taillight , connectors should be yellow to yellow & black to black on both taillights. Paul
Re: 1986 W150 tail light issue [Re: Racer33] #2609229
01/20/19 04:06 AM
01/20/19 04:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Losing ground back there?
Re: 1986 W150 tail light issue [Re: Racer33] #2609265
01/20/19 11:42 AM
01/20/19 11:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree check the grounds at the rear.Remember they ground thru the screws that hold them to the body.Also check under the truck for wires melted by heat.Had that problem on one of mine.Rocky
Chrysler Firepower
