318 head flow #2608835
01/19/19 12:35 AM
01/19/19 12:35 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
What kind of flow numbers have you seen from untouched 318 castings? Particularly 675 castings. What flow bench and test depression did you use?
Started in on a set of 675 heads with no intent to flow them when done. Now the wheels are turning and I'm kind of curious as I'm actually putting some effort in them, and didn't do a before test. 1.94/1.6 valves, gasket matched to 340/360 port size, bowl work, short side rework, removing most of the guide boss. Shooting for 210 cfm range with high velocity.
Re: 318 head flow [Re: skrews] #2608965
01/19/19 01:44 PM
01/19/19 01:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I haven’t messed with any of those in over 25 years.
From what I recall a stock head was around 160-165cfm, and one with cleaned up ports, valve job, back cut OE valves got you close to 180.
On the 2bbl oval track motors I was building at the time, the rules were any stock la head, 1.88/1.50 valves, no porting.
On those builds, 596 heads with 1.50 ex valves made about 40hp more than 302 heads that had 1.88 intake valves installed.
Re: 318 head flow [Re: skrews] #2609075
01/19/19 06:28 PM
01/19/19 06:28 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Skrews, as I know you are a member there, you have probably already seen this. https://www.forabodiesonly.com/mopar/threads/318-head-porting-for-the-average-joe.167865/
Re: 318 head flow [Re: forphorty] #2609418
01/20/19 05:45 PM
01/20/19 05:45 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I had this re-manufactured 318 head laying around,and my flowbench was already set up for a small block. I threw it on. I couldn't get to.500 lift, Went bind at .495. This was a re-manhead that was all stock from a local shop.
Re: 318 head flow [Re: skrews] #2609567
01/20/19 10:04 PM
01/20/19 10:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
There you have it up
Re: 318 head flow [Re: skrews] #2609768
01/21/19 09:36 AM
01/21/19 09:36 AM
Aus
hysteric Offline
hysteric  Offline
Aus
My 302's with a 1.9 11/32 valve flow 240+, I would imagine that the 675's would do the same.
Re: 318 head flow [Re: skrews] #2610169
01/21/19 11:43 PM
01/21/19 11:43 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Thanks for the replies.
