Page 1 of 3 1 2 3
DC 590 camshaft comparison #2608361
01/18/19 12:42 AM
01/18/19 12:42 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
I currently run this old cam in a 383 that has run a best of 9.86 at 137mph at 3100lbs.
Has anyone tried a different cam in a similar combination and found big gains?
I have heard many say this old cam is a dinosaur but I think it works pretty well.
Hutch
Re: DC 590 camshaft comparison [Re: Hutch] #2608363
01/18/19 12:45 AM
01/18/19 12:45 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
9.86 @ 137mph at 3.1klbs with a 383 is more than "pretty well." Don't touch it! wink
Re: DC 590 camshaft comparison [Re: Hutch] #2608402
01/18/19 02:18 AM
01/18/19 02:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah what else is done to that 383?
Re: DC 590 camshaft comparison [Re: Hutch] #2608408
01/18/19 02:27 AM
01/18/19 02:27 AM
fullmetaljacket Offline
Let leaping dogs glide.
Leave it alone.
I'm lighter than you. Sell me that motor as is. LOL.
You're flying with old news and much salutes.
Re: DC 590 camshaft comparison [Re: GTX MATT] #2608428
01/18/19 03:32 AM
01/18/19 03:32 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I’m going to guess...ALOT.
Re: DC 590 camshaft comparison [Re: cudadoug] #2608443
01/18/19 04:29 AM
01/18/19 04:29 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Yeah, that would have to be pretty stout.
Re: DC 590 camshaft comparison [Re: Hutch] #2608495
01/18/19 10:59 AM
01/18/19 10:59 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If you have enough valvespring then put a 1.6 rocker on the intake. Wallace shows you're only making 615 HP now so with a 'good' stage6 (340cfm) head you could make 650-675 still using a flat tappet and using respective parts/combo. Conversely, I don't see it being worth your while to mess with a cam that hasn't wiped the lobes and is running respectable given what I know/assume about the motor.
Re: DC 590 camshaft comparison [Re: Hutch] #2608566
01/18/19 02:00 PM
01/18/19 02:00 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Sounds like the dinosaur cam is working well in that 383! Curious to know the rest of the combo... I'm guessing the right roller cam would pick up power, if that's what you're after.
2 kids and a dog
Re: DC 590 camshaft comparison [Re: TonyS451] #2608869
01/19/19 02:15 AM
01/19/19 02:15 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
Thanks for the reply guys. It's an 11:1 383. 060" over. 1st design stage 6 straight plug hand ported heads 2.14 1.81 valves with a 7.100 rod.
It does work well but of course every time I get asked about it I always hear about how old the cam design is.
I'm building a 406cid twin to this now and I have another dinosaur going in. Lol
Hutch
Re: DC 590 camshaft comparison [Re: Hutch] #2608893
01/19/19 03:48 AM
01/19/19 03:48 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Old age and treachery always overcomes youth and enthusiasm. Lol.
A camshaft by definition is "old" technology. Lots of "new" cams not running 137 mph at 3100 lbs with a 383.
Kevin
Re: DC 590 camshaft comparison [Re: Hutch] #2608896
01/19/19 03:58 AM
01/19/19 03:58 AM
AndyF Offline
AndyF  Offline
I'm a little surprised that the 590 cam works that well with the Stage VI heads but evidently those two are happy with each other in your engine. It can be hard to improve on a combo that is working well. I've spent a bunch of time (and money) on the dyno testing the latest trick cam only to find nothing or go backwards.
Re: DC 590 camshaft comparison [Re: Hutch] #2608922
01/19/19 11:19 AM
01/19/19 11:19 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have a .590 in a 440 @ 3,000lbs,Stage 6 heads,6bbl intake ,93 gas.
have run 136mph in Ohio.
not as fast as your 383 ,,,,,STOUT combo!!
Good tuning skills. bow
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: DC 590 camshaft comparison [Re: Hutch] #2608945
01/19/19 12:54 PM
01/19/19 12:54 PM
UK
rb446 Offline
rb446  Offline
UK
According to my no's your making 648fwhp@3100lbs
60 Foot E.T. : 1.36
1/8 Mile E.T. : 6.19
1/8 Mile Trap Speed : 109.76
1/4 Mile E.T. : 9.81
1/4 Mile Trap Speed : 137
Thats some HP with that spec motor.
My mates 12.5:1 440 Dart with 317cfm Eddy's and the .590 cam only managed 132mph and 10 teens best@3150lbs and thats@sea level@SPR raceway...that was 600hp.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: DC 590 camshaft comparison [Re: rb446] #2608955
01/19/19 01:24 PM
01/19/19 01:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What is the compression height of a low-deck 383 with a 7.10" rod? That's a 2+ rod ratio, which is uncommonly high. (We're still talking a 3.375" stroke, right?)
Got flow #s for the heads? And are they standard port or MW?
What's the induction system?
What sort of RPM are you spinning it?
Auto or stick? How much stall, if auto?
Regardless, it hauls a$$ for what it is.
Re: DC 590 camshaft comparison [Re: BradH] #2608959
01/19/19 01:34 PM
01/19/19 01:34 PM
moparx Offline
moparx  Offline
if automatic, what converter and rear gear ?
beer
Re: DC 590 camshaft comparison [Re: moparx] #2609176
01/20/19 12:04 AM
01/20/19 12:04 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
It's an oddball combo for sure. Pistons were custom made in 1972. They are. 927 pin,. 200 dome,. 043. 043 3/16 inboard locks with a tiny skirt. Head intake ports are matched to the. 060" intake gaskets that used to come with a belly pan. I had a collection of them so it seemed like a good fit. Exhaust ports were raised in a D port design and I made custom header flanges to fit. CH of the piston is 1.195 from memory and crank is 3.365" and still Chrysler diameter. There were no rockers for these stupid heads so I used crane golds with Jesel Buick adjusters and Chevrolet push rods. I shift this between 7500 and 8000, the converter is an 8" I made that goes about 6400 on the hit. Intake is a Victor with a 2" velocity spacer and an old carb shop 930 with an air cleaner and the car has header mufflers.
Re: DC 590 camshaft comparison [Re: Hutch] #2609489
01/20/19 07:47 PM
01/20/19 07:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It sounds like it runs pretty good now. My cam is a custom grind from Dwayne Porter in my street car and it sorta close to the MP .590 but its ground for my combo. Which my 63 weighs over 3700 lbs and I run a full exh but its specs are 264 & 270 @ .050 with .585 & .592 lift with a 110 LSA. I have it in the eng on a 106 ICL. But your cars runs pretty well now. Ron
Re: DC 590 camshaft comparison [Re: Hutch] #2609629
01/20/19 11:15 PM
01/20/19 11:15 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
It would be nice to see some back to back track testing with some of the newer cams if anyone has done it.
Re: DC 590 camshaft comparison [Re: DblOJoe] #2609650
01/20/19 11:53 PM
01/20/19 11:53 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
Mr Hutch,
I'm quite interested in this motor combination, so it
does not have the long 7.100 rods ?
Re: DC 590 camshaft comparison [Re: hemienvy] #2609693
01/21/19 01:09 AM
01/21/19 01:09 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
Yes it has 7.100 rods in it.
Hutch
Page 1 of 3 1 2 3
