Re: Wedge mega block- what kind of power can that block handle
[Re: Jeff440sc]
#2608314
01/17/19 11:18 PM
01/17/19 11:18 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have not ran one myself at those power levels but dear God they have nearly twice as heavy of cylinder walls, decks and mains from the old blocks. One would think durability wouldn't be a problem. I wouldn't give it a second thought.
2011 Drag Pak Challenger
[Re: fbs63]
#2608756
01/18/19 08:53 PM
01/18/19 08:53 PM
Posts: 16 MI
Jeff440sc
MI
I have seen them split through the cam bores with a blower and no crank support at about 1000 hp. Ok but can you rule out that it didn't happened because the engine was out of balance( harmonics) or detonation? Someone on this forum has to have pushed the block over 1000hp and made it live or is 1000 hp the limit to be on the safe side. Switching to an aluminum block is expensive.
[Re: Jeff440sc]
#2608815
01/18/19 11:33 PM
01/18/19 11:33 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
The original street and OEM "race" cast grey iron hemi blocks where used in both top fuelers and funny cars until Donovan and Milidon came out with cast aluminum blocks in 1971 or so. I'm sure all of those old motors far exceeded 2500 HP even back then on nitro fuel On your deal I wouldn't worry at all up to or over 1500 HP with a good tune
[Re: Cab_Burge]
#2608856
01/19/19 01:41 AM
01/19/19 01:41 AM
Posts: 16 MI
Jeff440sc
MI
The original street and OEM "race" cast grey iron hemi blocks where used in both top fuelers and funny cars until Donovan and Milidon came out with cast aluminum blocks in 1971 or so. I'm sure all of those old motors far exceeded 2500 HP even back then on nitro fuel On your deal I wouldn't worry at all up to or over 1500 HP with a good tune Yea but some teams retire the good BAE TFXtop fuel blocks after 50 runs....but we are not running nitro. The only reason I am concerned is because this information came from a reputable builder. Obviously the block could be less susceptible to stress cracks at a lower power level. The block would also live longer as long as the tuneup is not on the edge. No lean misfire to upset the load balance. Only 2 options - blame the block failures on a bad tune or a time related high load metal fatigue factor. Lets take into consideration metal fatigue because an engine is dynamic. Its cant be in perfect balance over the entire rpm band. Lot of people will over balance a crank if they know its going to operate strictly hi rpm band as a race engine. Have you ever stood next to an engine on a dyno when its at wot while making over 1000hp ? You can feel the ground shaking at high rpm. Its not like watching it on the engine on a video. The mean piston speed, rotating weight on the bearing increase as you turn up the rpm /boost/power. Keep turning up the power with a steel block... caps start to fret more on these non dowel main caps- lots of force trying to push out the crank out of the block. The firing order has some effect on flexing the crank in the block. Some people think a non Mopar firing order may give a v8 better load balance.. So no two engines are the same. Who can say why that mega block split in half? The other builder told me he seen the same type of failure at 1000 hp . What caused the metal fatigue or stress cracks before this broke ? These block could be tested for durability. I doubt its every been tested by the manufacturer to find out it limitations from a flexing metal fatigue issue. You can get away with murder in an 1/8th mile, but keep bending the coat hanger back and forth without lifting and then what happens? Aluminum caps in the stock 440 block helped you get past 650hp. I Need more people to say the balance was off on these broken steel blocks to rule out metal fatigue flex factor over 1000hp. I asked Barton this question at one time and he said it would handle more but like anything you take your chances. Even a Carrillo rod can break for no reason. So this Mega block in a bracket car, the temptation to speed up the supercharger is a battle of the mind. One side thinks of going faster and the other side thinks about the cost of a broken block. Just one more pound of boost ! Of just 1/2 degree of timing... just leave it alone. Thanks to everyone that takes the time to read and give their time, experience, or opinion .
[Re: Jeff440sc]
#2609005
01/19/19 03:29 PM
01/19/19 03:29 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
545 inch roots blown,I am more concerned with melting pistons than making more than 1000 HP!!
[Re: hemi-itis]
#2609217
01/20/19 02:32 AM
01/20/19 02:32 AM
Posts: 16 MI
Jeff440sc
MI
What blower and how much boost?
Its a Whipple 510R. The 510's are very nice efficient super charger. I am only spinning it 6 percent over and see 14 psi flat across the rpm band. It flows 3200cfm at 12000rpm . So 1500 hp is very doable. Car ran 9.0 at 3600lbs with a 3.5 gear last year. Mostly was a street car. Putting the 4.10 gear back in now. More fun to just race it at the track then play on the street.
