cascar intake question #2591033
12/12/18 08:52 PM
12/12/18 08:52 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I bought a Cascar intake from Prefix(very Nice piece) I have one question. on some of the other intakes they offer a filler neck cover, some of these have a spot to put a breather. since I am not running the factory PCM will I need to add a breather to the oil fill cap they provided?
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2591702
12/14/18 10:48 AM
12/14/18 10:48 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I bought a Cascar intake last month, so I was looking at the same thing.. Thats what Im planning to do, breather at the cap.. Looks like there is no provisions for a MAP sensor also...
Re: cascar intake question [Re: Kiddart] #2591908
12/14/18 04:05 PM
12/14/18 04:05 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
for me the map sensor is in my throttle body. I am going to see what happens first before I drill a hole in the cap. the cap with breather is like $240. outrageous
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2592161
12/15/18 01:30 AM
12/15/18 01:30 AM
Mrytle Beach SC
Mrytle Beach SC
Im just gonna use a breather instead of a cap, like what Joe includes on the OC performance intake .
Re: cascar intake question [Re: Kiddart] #2607740
01/16/19 09:22 PM
01/16/19 09:22 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Ok has anyone any other ideas? Prefix supplied me with a cover plate, no gasket. it could become a pain in the butt adding oil if needed. I have been searching ways to adapt a stock filler to the intake but no such luck. any help and suggestions welcome. keep in mind this intake does not have the threaded boss area that the Ritter and the OC intake has.
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2608050
01/17/19 01:41 PM
01/17/19 01:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
John, sounds like you should start making adapters
Re: cascar intake question [Re: Kiddart] #2608907
01/19/19 09:18 AM
01/19/19 09:18 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
No experience with Gen3 hemis but i cant realy see that being a big problem,your engine will have a breather somewhere just fill where it is,if you engine is totaly sealed and dont have a breather then just take of a valvecover and add oil that way.
It cant be a huge isue unless your engine uses alot of oil and in that case you have a much bigger isue at hand than how to add more oil.
Re: cascar intake question [Re: sixpackgut] #2609408
01/20/19 05:30 PM
01/20/19 05:30 PM
Mrytle Beach SC
Mrytle Beach SC
YUP, but it isnt rocket science
Re: cascar intake question [Re: Kiddart] #2609782
01/21/19 11:02 AM
01/21/19 11:02 AM
Mrytle Beach SC
Mrytle Beach SC
https://www.ebay.com/itm/New-Aluminum-Vented-Cap-Bung-MADE-IN-USA-Vented-Filler-Neck-Kit-Valve-Cover-X/321831231655?hash=item4aeea2e0a7:g:P2oAAOSw9N1VzAu-:rk:10:pf:0
Re: cascar intake question [Re: Kiddart] #2609830
01/21/19 12:57 PM
01/21/19 12:57 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
John, I never thought of this. I am sorry for my stupidity. that's is a fantastic idea!!!
thanks a million I am ordering one right now.
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2617044
02/04/19 09:42 PM
02/04/19 09:42 PM
Mrytle Beach SC
Mrytle Beach SC
Re: cascar intake question [Re: Kiddart] #2617242
02/05/19 11:40 AM
02/05/19 11:40 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
ouch is right. I have made a solution and will be getting a few 3D printed to see how they work.
thanks for all the help.
by the way Mancini's sells a breather cap with a threaded nut for $5 bucks. they are sitting on the counter. tig the nut to the plate do some creative hole grinding and you have a solution. or get the one that was mentioned above. either will work, when I get mine back I will snap some pictures and post.
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2619727
02/11/19 12:08 PM
02/11/19 12:08 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
just the first printout. this material is only good up to 190 degrees. looking for something different. I will check the fit this week when I have time
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2619728
02/11/19 12:14 PM
02/11/19 12:14 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I can make that from aluminum for you if you want. especially if you have the cad already.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: cascar intake question [Re: Kiddart] #2619738
02/11/19 12:33 PM
02/11/19 12:33 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I have the original one that is alum. I am just seeing what can be done on 3d printer.
Thank you
Kiddart
Re: cascar intake question [Re: Kiddart] #2620700
02/13/19 10:28 AM
02/13/19 10:28 AM
Mrytle Beach SC
Mrytle Beach SC
Very nice.. Thats what I had in mind. What was the part # on the Aluminum Cap and neck assembly from Mancini ?
Re: cascar intake question [Re: Kiddart] #2620752
02/13/19 01:28 PM
02/13/19 01:28 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I don't recall, they are in a box on the counter, next time I am in there I will get the number.
Thank you
Kiddart
